Old 11-14-2015, 08:01 PM
Senior ClubCobra Member
Default Won't Start When Hot
This topic comes up on a regular basis; the car won't start when the engine is at temperature. I had this problem. I've read all the posts. It can be many things and I tried fixing them all (except one). Nothing worked. I changed the starter, I re-wired the ground to the frame. I checked the battery and all the wiring and connections. Then I redid the ground by running a separate ground wire from the battery directly to the starter. I changed out the solenoid. I put on a heat shield. Nothing worked.
I tried another starter. This time, I went with a Summit Racing mini-starter made for high compression engines (I have a mild 10:1). That fixed it. After dinking with this for a very long time, the stronger starter was the answer. Just FYI for those of you that may be dealing with this.
Summit Racing® Protorque Starters SUM-820056 - Free Shipping on Orders Over $99 at Summit Racing
Old 11-15-2015, 01:07 AM
*13*'s Avatar
Pretty common non start issue, at temp. Those little demons can drive you crazy! Glad you got it resolved,
ERA FIA 2088
Display Modes
