Like Tree1Likes
  • 1 Post By blykins
Old 11-16-2015, 10:26 AM
Much wider on a Windsor. A Windsor block is 9.500" deck height. A Cleveland is 9.200" deck height.
Also, your pistons won't work with the Cleveland heads and there is some drilling/plugging that you'll have to do to make the C heads work on a W block.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 11-16-2015, 01:14 PM
cycleguy55's Avatar
Brent: I'm not doubting what you wrote - you probably see more engines in a week than I will in my lifetime!
I am, however, thinking of my math / trigonometry lessons from a few decades ago, and it seems to me that, all else being equal, a 0.300 higher deck height would result in the ports being 0.21" higher and wider. Looking at my car I could easily see how that difference could be accommodated without changing either the headers or side pipes.
I'm probably over-simplifying this, so I'm relying on your expertise to point out what I'm missing!
Brian
Old 11-16-2015, 04:41 PM
The issue is where the sidepipes exit the body.
Any header will bolt onto those heads, but if you want the sidepipes to exit without body work, then you have a problem.
cycleguy55 likes this.
