Old 11-23-2015, 10:30 AM
Cobra Make, Engine: ERA 575 with Shelby Aluminum 427 Stroked to 468
Default Valve Lash on a Coast High Performance 427 (SBF Windsor)
Hey all,
Trying to figure out the valve lash setting for my motor. It's a Coast High Performance carbureted motor based on 351 Windsor. Has AFR heads and edelbrock intake. We are removing the heads and trying to anticipate (assuming it's a solid cam) what the valve lash is so we can properly adjust them. If it's a hydraulic cam, the valves get set to 0. Does anyone know if there is a benchmark guide for lash assuming a solid cam?
Old 11-23-2015, 11:18 AM
You would really need the cam specs. Solid rollers can vary in lash from around .016" up to .030", depending on the lobe profile.
No documentation on the engine?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 11-23-2015, 11:35 AM
I am going to see if CHP/Probe Industries can provide a build sheet based on the block casting ID.
