Like Tree7Likes
Old 04-09-2016, 01:24 AM
Jac Mac's Avatar
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Added pic of raw forging and finished crank. Note also 'simple' headers that couple cylinder 1 & 3 , 2 & 4 of each bank.
Jac Mac
Old 04-09-2016, 11:19 AM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
Are you sure that header was intended for the flat plane crank? It fires inner, outer, inner outer( just looking at the one bank), so the proper pairing would be 1&4 an 2&3 or inners together, and outers together.
Old 04-09-2016, 11:39 AM
The crank and header is in the picture it would fire 1 and 3 360 degrees apart and 2 and 4 360 apart. The other bank does the same thing but is out of phase 90 bank to bank.
mark
Old 04-09-2016, 12:17 PM
That's odd. Why didn't they do it up down down up like most 4 cylinder cranks? Then you don't need nearly as much counterweight as 1 and 2 balance each other and 3 an 4 balance.
As the rough forging is, there's a bit of a wobbly vibration that can be eliminated by doing it the other way.
I didn't notice the crank at first glance.
Old 04-09-2016, 04:52 PM
Jac Mac's Avatar
That only really works for inline 4's and when you increase the stroke your into really light ( read Expensive ) rods and pistons plus balance shafts, being the V8 and common pin your stuck with the extra rod BE weight on each journal and since they have used the modular bore spacing large capacity increases are more likely to have to be stroke rather than bore size. I guess I really am turning into an old ford is good ford fan after all these years. Don't think the current fans will be able to think the same!
Jac Mac
Display Modes
