Like Tree9Likes
  #41 (permalink)
Old 06-02-2016, 06:10 PM
Senile Club Cobra Member
Originally Posted by Armrer View Post
Yep, the M-6007-X302B is the unit as you mentioned. 345 hp, call them for a dyno sheet to rpm/power spread. Great engine.
The T5 is a good call. V is right on that, looking back I would have picked it over the TKO 600.
The T5 world class is fine but the .64 overdrive puts many engines in a "no go" rev range at normal (65-80) MPH speeds where the TKO .82 allows use of fifth without lugging/bucking/being under the comfortable range of the engine.
Again, careful analysis of how and where you will be driving will help in proper powertrain selection.
The tires on your roller will be selected by the dealer. The factory provides no tires so request what you want and pay the difference to the dealer to bridge the gap from what they "give" you to what you really need.
rick@autoventureusa.net
  #42 (permalink)
Old 06-02-2016, 06:18 PM
thanks - what size is typical for a 289 slab?
I am a big believer in spending more money for good tires vs. garbage ones.
  #43 (permalink)
Old 06-02-2016, 06:22 PM
joyridin''s Avatar
You mentioned running EFI. If tuned properly, you won't have many issues with that engine bucking at low RPM's on the highway. I have a .54 OD with a nasty cam and EFI and on the highway at 70 mph pulling about 1900 RPM's, it run like a dream.
  #44 (permalink)
Old 06-02-2016, 07:35 PM
Bernica's Avatar
Senior CC Premier Member
Originally Posted by RET_COP View Post
The stereo is good for when I'm parked overlooking the bay or quiet scenery and I want some music. When I'm driving, I like the sound of the car which usually overrides the music anyway. You should see the looks I get in a resort area when I parked eating an Ice cream listening to Led Zeppelin.
Nice Ret_Cop! I just use a portable bluetooth speaker and keep it in the trunk. When I'm ready for SRV, ZZ Top, Zepplin or AC/DC, I can just pull it out of the trunk and blast away!
  #45 (permalink)
Old 06-02-2016, 08:53 PM
Cobra Make, Engine: SPF 289 Street
Originally Posted by jordanm View Post
Armrer - I think you guessed which shop I was talking to on this?
I did.
MKIV does have a valid point on the tall 5th gear on the TKO. The T5 is at its limit, torque wise with the above engine. Although it is stronger, I wish the TKO shifted as smooth as the T5, but I understand they get better after about 2k miles.
  #46 (permalink)
Old 06-02-2016, 11:20 PM
LMH's Avatar
LMH LMH is offline
And I think I am leaning back to the easy X302B and T-5 combo. Simple plain driver, and with EFI super reliable.
The Superformance 289 comes with a set of tires already I believe?
The T5 is an awesome transmission! I haven't crossed this bridge yet but I've done some research on T5's and shifter location. In an original car with a BW trans, the shifter is 16" back from the bellhousing. There is a couple ways to get a T5 with it's shifter location in that position but it takes some fitting of different tailshaft housings and cases. Possibly a custom output shaft as well, depending on what components are used.
This is of course, all dependent on engine location, body and interior panel placement, etc, as compared to an original car. It's also dependent on your requirements of how accurate you want it to replicate. My 289 isn't an SPF, it's a HiTech/Sagebrush, so I can't really advise on all of those aspects of SPF. Just saying it's something you might want to look at before you get going on the car.
Alba gu brąth
  #47 (permalink)
Old 06-03-2016, 02:48 AM
The most common is a 205/70x15 (or 75 series t be closer to original) but as Amrer has indicated a 215/70 will fit. He has had a lower performance Firestone on his car, he then upgraded to Blockley 205s (Blockley Tyre - Vintage and Classic Car Tyres) but has now fitted Michelin 215s (XWX | Michelin Classic)
And I would put the Avons as equal or better to any choice SascoSports Inc is a full-function racecar preparation restoration shop Rally-CR6ZZ-DOT&tire_size=205/70R15 96V&std_rim=&rim_diameter=15
Note these are not cheap, but why spend thousands on "horsepower" and balk at hundreds to allow it to be used?
  #48 (permalink)
Old 06-03-2016, 09:28 AM
So about $400 each for the Michelins...still cheaper than what I pay for tires on my other cars :-)
  #49 (permalink)
Old 06-05-2016, 02:23 PM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
oops!!
  #50 (permalink)
Old 06-05-2016, 02:25 PM
If you're a HP junky, don't let anyone tell you 350 HP is too much or you'll be back in 6 months asking about fitting a supercharger or turbos or nitrous.
If you're building a slab side, you obviously want a 8.9" block. I would highly recommend a 347 for the extra 45 CI. It's either a free extra 50 HP or a lot more grunt on the low end, however you balance the cam.
I run 315 toyo praxis 17", and wouldn't mind a little more power than my 535 HP EFI 427 winsor has. Passing the toll both, I can slow to 50 MPH, drop it in 3rd and hit is full force and accelerate to 100at full throttle. Then in 6th, purr along at 1800 RPM at 70 or so.
But no, the radio is useless if the motor is running.
Again, with the slab side, you're limited on tires; it cost to play. DON'T SKIMP ON THE RUBBER! It's the most important 80 square inches you have on the car.
