4Likes
10-18-2016, 07:40 PM
NC
Cobra Make, Engine: Factory 5 mk4 445 FE
Windshields breaking
Of all the different brands that are out there in Cobra land... do you guys hear of windshields breaking very often?
10-18-2016, 07:54 PM
I'm on my third windshield.
It's covered by your comp insurance. You might want to drop your deductible to $100 because if you do a lot of driving, you'll be replacing windshields.
10-18-2016, 07:56 PM
Cobra Make, Engine: SPF#0760
Owners who "snug-up" the screws periodically have had problems. The screw end contacts the edge of glass and that can cause a crack radiating from that touch point. On side wings or WS mounting side bracket screws this is especially true. Some cars that had center bars experienced the same problems early XKE's did with cracking glass too. Passengers tend to use windshield frame as a handle when entering or exiting the car.... A definite no-no.
SPFWiringDiagrams@Comcast.net
10-18-2016, 09:53 PM
46,000 miles and putting in #4. This last one was a huge rock that hit right in front of my wife!!
Dam truck thought he was doing a favor pulling on the FN shoulder doing 60mph throwing up all the rocks!
Scott
10-19-2016, 09:22 AM
Cobra Make, Engine: FFR fat block tko 600 9"
55,000 miles, so far so good! Lots of flex at freeway speeds makes me nervous.
If aliens are so smart, why do they always choose to talk to guys named Bubba?
10-19-2016, 11:35 AM
NC
Just wondering if different brands were having the same problems. It seems the F5 guys have a lot of these issues.
Like above, the little screws can be screwed in to far... need to have a couple of threads cut off.. and the other issue that seems to help is the way your windshield post are mounted... washers used as spacers... to get the right fit without bending things out of wack.
10-19-2016, 11:46 AM
Al,
I thought I had done everything possible to prevent that from occurring. Replaced the brass strips with stainless steel bar and shortened the screws and it still cracked. When I installed the replacement glass in 2006 I dressed the ends of the screws again and so far so good.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
10-19-2016, 12:30 PM
GA
Cobra Make, Engine: Backdraft #949, 392 FMS
Was wondering if anyone has tried the scratch resistant lexan? Miy windshield split right down the middle, but was wondering if anyone had any luck with the lexan before ordering a new windshield. Not to mention, no shop wants to mess with installing the new glass and say hey can't be responsible if it breaks while being installed. Guess I could run a piece of chrome trim and make it a one of a kind split window Cobra!
10-19-2016, 01:33 PM
I don't believe that Lexan or poly-carb are DOT legal for a windshield in some or all states. What the ramifications would be from your car insurance in the event of an accident I don't know. Same goes for Billboard tires I believe and our little red taillight lens. Also, if I recall correctly, our large racing type seat belts and shoulder harnesses..... go figure.....
10-19-2016, 09:21 PM
Fast Freddies makes a polycarbonate screen.
10-19-2016, 10:37 PM
Cobra Make, Engine: 65 Cobra w/351W
My glass windshield cracked from the screw tightening problem and had a nasty chip anyway. Replaced it with a fast Freddie's Lexan windshield and have been on some pretty long drives on Arizona and reservation interstate highways with no problems. And it takes speed just fine. Doesn't flex anymore than the glass did. Best thing was that it was a very easy install. Wife and I did it an about an hour or so at home.
I'm not broke. I'm Hot Rod poor!!
10-20-2016, 01:57 AM
WC
Cobra Make, Engine: Shamrock
25 years and nary a broken windshield.
10-20-2016, 03:34 AM
SA
If you have a new glass installed, would it be a good idea to have some glass ground away, where the screw holes are. There is not much thread to play with in the first place, and I'm afraid of having the screw too short and stripping the thread.
JD
10-20-2016, 07:08 AM
NC
A lot of the F5 guys are going to the Lexan windshield. They seem to really like it.
10-28-2016, 11:33 AM
Cobra Make, Engine: FFR5, 300hp of entertainment
My first windshield got so pitted I couldn't see when driving into the sun. I replaced it with a lexan shield from Fast Freddie. Much lighter and good optics. Can't wear my polarized glasses though. White cars look pink and asphalt patches look shiney like spilled oil. Pitting is way less than glass. I have a ton of miles on it with no problems.
Drive it everyday or else.
10-31-2016, 10:40 PM
AB
Cobra Make, Engine: Butler Racing/427 side oiler
Yup...made my own Lexan and have had zero problems. Love it...and not expensive either
10-31-2016, 11:41 PM
How does one contact Mr. Fast Freddie about these Lexan windshields?
11-01-2016, 05:59 AM
He has ads on Ebay all the time. It is really easy to make one of your own. Make a template of the windshield, go to a place that sells scratch resistant Lexan and have it cut. Install and done.the place near me charges $125 for the lexan cut to the shape of the windshield.
11-01-2016, 07:10 AM
OR
11-10-2016, 08:58 AM
Cobra Make, Engine: SPF 239
I love my little windshield! Ill never go back
