Old 01-11-2017, 01:33 PM
Default Engine Oil
This has probably been talked to death.
I have an early 302 putting out nearly 400. With the extra capacity pan, dual filters and oil cooler, its just over 9 quarts. I would like to go to synthetic, but am concerned about the viscosity. AND being an old Ford not used, the leaking problem.
Old 01-13-2017, 06:30 PM
Cobra Make, Engine: Researching the right car now.
Unless it was run with synthetic from day one, i would stick with conventional.
Old 01-13-2017, 08:01 PM
RET_COP's Avatar
I've used both many times and never had a leak with synthetic. I'm back to regular HR-5 Driven. I like the cling to metal parts in storage it has as well as it's package.
Lou
Old 01-14-2017, 04:44 PM
Dwight's Avatar
Smile
I had a '90 model 5.0 (302) making over 300 hp & tq to the rear wheels. Drove 1500 miles and changed to synthetic (Mobil One). It did not leak nor could I see it burning oil but it used qt to qt half per 1000. I changed back to dinosaur oil.
My rule is; if the motor was build by the manufacture to use synthetic oil, then use synthetic oil. If not, use the oil the motor was designed to use.
Dwight
Old 01-14-2017, 04:46 PM
Dwight's Avatar
Smile
https://bobistheoilguy.com/
Old 01-17-2017, 06:17 AM
G-Pete's Avatar
Why?
DRB GT40 MK1 red #49- sold
SPF 2063
