November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 01-11-2017, 02:33 PM
Default Engine Oil
This has probably been talked to death.
I have an early 302 putting out nearly 400. With the extra capacity pan, dual filters and oil cooler, its just over 9 quarts. I would like to go to synthetic, but am concerned about the viscosity. AND being an old Ford not used, the leaking problem.
Thanks
Old 01-13-2017, 07:30 PM
Cobra Make, Engine: Researching the right car now.
Unless it was run with synthetic from day one, i would stick with conventional.
Old 01-13-2017, 09:01 PM
RET_COP's Avatar
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
I've used both many times and never had a leak with synthetic. I'm back to regular HR-5 Driven. I like the cling to metal parts in storage it has as well as it's package.
Lou
Old 01-14-2017, 05:44 PM
Dwight's Avatar
Smile
I had a '90 model 5.0 (302) making over 300 hp & tq to the rear wheels. Drove 1500 miles and changed to synthetic (Mobil One). It did not leak nor could I see it burning oil but it used qt to qt half per 1000. I changed back to dinosaur oil.
My rule is; if the motor was build by the manufacture to use synthetic oil, then use synthetic oil. If not, use the oil the motor was designed to use.
Dwight
Old 01-14-2017, 05:46 PM
Dwight's Avatar
Smile
https://bobistheoilguy.com/
Old 01-17-2017, 07:17 AM
G-Pete's Avatar
Why?
DRB GT40 MK1 red #49- sold
SPF 2063
