Old 05-19-2017, 10:59 AM
Cobra Make, Engine: Unique 289fia
Default Jag rear Axel nut torque spec.
I am installing pin drive wheels today. I noticed that my left Axel nut is hand tight. If the cotter key was not there the wheel most likely would have exited
the car. So ,what is the torque setting on the Axel nut?
My old E-type shop manual says 140 lb.ft.. This rear is a little newer
but I would think that it will be close to that. If I don't hear back soon thats what I will torque it to.
Thanks, Ken
Old 05-19-2017, 12:06 PM
Now looking at the Axel nut, I wonder if it is only a tighten and back off for a wheel bearing preload. If thats the case then 140 lb. ft. is WAY to much.
suggestions? Ken
Old 05-19-2017, 12:38 PM
here is a picture of the nut in question
Old 05-19-2017, 04:42 PM
This may help
Jags are listed as well...
http://caissiedrive.net/abw/SKF_Torque_Specs2014.pdf
Old 05-19-2017, 05:00 PM
Tom Wells's Avatar
Nor,
This reference might help: Setting the Hub Carrier axle bearings
You might want to check the end float in that hub after you tighten it. There may be a bit more work to do
Tom
Old 05-19-2017, 07:55 PM
Thanks Tom and the rest for your help. Ken
