November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree13Likes
  • 8 Post By blykins
  • 1 Post By RodKnock
  • 1 Post By eschaider
  • 1 Post By patrickt
Old 07-08-2017, 04:04 PM
eschaider's Avatar
Originally Posted by db replicas View Post
Shouldn't you first dial in the gearbox mounting face of the bellhousing?
Otherwise no matter how accurate and central the hole is the tranny will be pointing in the wrong direction.
I do the bore registration with the crank first. Once that is accomplished you can check the parallelism of the transmission mounting face to the can's block mounting face.
I have usually found it needs little to no modification. Machining flat and parallel is a skill the manufacturers have a much better handle on. This particular can for example required less than a 0.002" surfacing cut to bring it flat and parallel and that was across about a 17 inch or so surface that mounted up to the block.
I chose not go into that discussion because most guys will not need to do the correction and unless you have a machine shop you will likely not have the surface grinder to do the work. Of course that doesn't mean you could not go to a shop to have it done. Be sure to strip all paint from the two surfaces before taking your measurements.
Ed
db replicas likes this.
