Old 08-23-2017, 09:53 AM
Cobra Make, Engine: Superformance , Roush 427SR dyno'd at 526 hp
Default Valve cover breather
I'm preparing for the last show of the year and I need some help. The motor in my car is a Roush 427SR and has the normal chrome valve cover breather on the driver side. I realize that it is a breather but the oil that leaks out drives me crazy especially when I drive the car to a show. I have tried the old hot rod trick of cutting a piece of sponge the size of the breather and placing it between the valve cover and the breather itself. It is like a doughnut with a hole in the middle to let the neck slip through. This works OK if the car is not driven too far but on longer trips I still get the leakage once the sponge gets saturated. Does anyone have another soloution?
Old 08-23-2017, 10:03 AM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
I run breathers on both valve covers that have the exposed pleated filter element and I just made some gaskets for the sealing surface out of some 1/8" neoprene rubber. The gaskets are about a 95% solution to the oil seepage.
Ted
Old 08-23-2017, 05:36 PM
I did a very similar fix as Shootnride.
Mark.
Old 08-24-2017, 02:35 PM
Cobra Make, Engine: Superformance #705, Ford Racing 460 - 514ci
Are you running a PCV setup? If not that would most likely take care of the problem.
