Like Tree4Likes
  • 1 Post By spdbrake
  • 1 Post By cycleguy55
  • 1 Post By Luce
Old 01-18-2018, 10:56 AM
Cobra Make, Engine: 2001 B&B cobra
Default GM Rear Metric Calipers with E-brake INFO NEEDED
Last summer, when I bought my B & B Cobra, the previous owner had rear disc brakes installed, using the GM Metric Single-Piston Calipers.
As of now, I have no emergency brake, due to using the calipers that are on it now. I would like to know if anybody knows the years and application for the Rear Metric calipers with the parking brake provisions, so I can hook up my cables and have an emergency brake.
All info appreciated. I know someone knows the application and/or parts numbers for the calipers that I need.
Thanks, Mike
Old 01-18-2018, 11:08 AM
From the B&B forums on this site (There are 4-5 threads about the emerg brakes, cables, routing etc...)
B & B Cobra's --- Speak with Bryan Anderson [Archive] - Club Cobra
hotrodyankee likes this.
Old 01-18-2018, 03:02 PM
cycleguy55's Avatar
Thanks, Mike
Based upon what you wrote it's not clear to me whether your calipers have provision for emergency brakes and they're not working, or your calipers don't have e-brake provisions. Please advise.
I have a set of GM rear single piston calipers on my Ford 9" axle - installed them myself from a kit I bought (MGP, I believe EDIT: MBM). They're the 'large' calipers that preceded the 'metric' calipers, but I believe the designs are very similar. I do remember the rear caliper adjustments were a critical part of the installation, plus there are strong warnings that you need to use the e-brake on a regular basis or you will lose the function of the rear brakes. Sample instructions on page 7 of this: http://www.jegs.com/installationinst...600_630601.pdf
Brian
Old 01-18-2018, 03:32 PM
I have a set of GM rear single piston calipers on my Ford 9" axle - installed them myself from a kit I bought (MGP, I believe). They're the 'large' calipers that preceded the 'metric' calipers, but I believe the designs are very similar. I do remember the rear caliper adjustments were a critical part of the installation, plus there are strong warnings that you need to use the e-brake on a regular basis or you will lose the function of the rear brakes. Sample instructions on page 7 of this: http://www.jegs.com/installationinst...600_630601.pdf
Hi Brian, I don't have the calipers that have provisions for the e- brake. what are the large calipers you used? Application?
Old 01-18-2018, 04:35 PM
cycleguy55's Avatar
I bought my kit locally - it's from MBM - here's a link: DBK9- Universal Ford 9" Rear-End Universal Disc Brake Kit - MBM Brakes
Installation instructions: http://piratejack.net/template/img/DBK9_v2.0.pdf
I had 2 issues to deal with when installing mine:
  1. I have a rear sway bar that interfered with the calipers, so I had to mount the calipers in front of the wheel, instead of the rear. That required me to use the left caliper on the right and vice versa.
  2. I had to extend the connection from my e-brake handle to the cables. I suspect this was more to do with the way my car was built than anything wrong with the kit. I used a short piece of steel tubing, internally threaded 5/16" NF to make the connection.
MBM doesn't sell to consumers / end-users, but various dealers do. Here's one:
Other than MBM, kits like these are widely available (e.g. Jegs, Speedway, Summit, etc.), and many of them include brackets to fit most, if not all, of the different axle ends Ford used over the years.
I know Jegs lists a couple, one for staggered shock rear ends and one for non-staggered shocks.
Summit has a couple of Rear Drum-to-Disc Brake Conversion Kits ( https://www.summitracing.com/int/par...1626/overview/ https://www.summitracing.com/int/par...1627/overview/ ) but I can't tell the difference between them - likely the staggered / non-staggered issue. A phone call to Summit would sort that out quickly.
Brian
Old 01-19-2018, 08:17 AM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
Here's what you're looking for...
https://www.ebay.com/itm/GM-Metric-R...haQtDe&vxp=mtr
I think it's a cady part from the early 80's. Like an elderado?
They can be a pita to get adjusted to not have too much pedal free travel.
Old 01-19-2018, 01:39 PM
Thanks for the info. All the research I have done, and those are the ones I need. Thanks all for the help.
