Like Tree4Likes
  • 1 Post By tortuga
  • 1 Post By tortuga
  • 2 Post By tortuga
Old 01-17-2018, 08:20 AM
Default Home sick project: fix flapping tonneau
Home with the flu "resting"
Bought the lift a dot kit with the machine thread studs (8-32) and the crimp on dots. Marked and installed one of the dots on the tonneau mid passenger door above the side curtain ferrule. This is a bit of a trick as you crimp to the upper layer of the two layer vinyl cover...takes a bit of maneuvering with some little dental tools.
The neat little device consists of one of the studs, an 8-32 coupler, another 8-32 bolt with its head ground off and finally a plastic know with 8-32 threads. I ardjusted the length then loctite red'd everything and put some shrink wrap to finish.
So install consists of putting the top on normally with th fwd passenger corner left open, reach under stick the little pin up through snap the cover on and done.
No more big gap over the door.
DOORGUY likes this.
Old 01-17-2018, 08:22 AM
Default Pic 2
Stupid iPad names all pics the same need to post multiple times for multiple pics...
DOORGUY likes this.
Old 01-17-2018, 08:24 AM
Default Pic3
LMH and DOORGUY like this.
Old 01-26-2018, 10:21 AM
FWB's Avatar
FWB FWB is offline
someone defaced your car by signing his name on it.......
damn kids.....
Fred B
Old 01-31-2018, 02:14 PM
t walgamuth's Avatar
I'm wanting to fit my car with a tonneau and possibly a top and side curtains. Is there a recommended source?
Old 01-31-2018, 08:42 PM
Karl Bebout's Avatar
I had a boat repair/upholstery shop make my tonneau cover. They have lots of experience with custom designs. I am very pleased with it and I didn't have an extortionate bill, afterwards. If you go that route, he sure to get the dividing zipper and two or three hold down straps to control flapping. Snaps won't make it On the hold downs. I used the male push and turn buttons that go through the female fitting. As far as the top and side curtains...hang on to your hat. Taint going to be low buck.
Karlos
Old 02-01-2018, 08:24 AM
Default Flapping Cures
Also thinking about having a sail-maker friend sew in a batten down the middle so as to stiffen it up for solo riding half closed.
I am very partial to doing this as the heater is MUCH more effective with half the cockpit closed off.
Steve H
1764
Old 02-01-2018, 11:36 AM
You have a heater?
Old 02-01-2018, 11:45 AM
What’s a heater for?
Jim
Old 02-01-2018, 01:40 PM
Exactly. It'll just add weight!
