November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 03-03-2018, 11:11 PM
Jim Coleman's Avatar
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Default Jag XKE Rear End Positraction Disc Replacement
What all is involved in changing out the positraction discs in an XKE rear end ?
Thanks,
Jim
Old 03-04-2018, 05:16 AM
Tom Wells's Avatar
Jim,
Here are a couple of items to get you started: http://clubs.hemmings.com/potomacram...iff_5315-3.pdf
and
https://www.jaguarclassicparts.com/u...nents-powr-lok
If you want more, use an internet search and look for Powr-Lok and whatever other terms you think may apply.
Have fun,
Tom
Old 03-04-2018, 06:20 AM
joyridin''s Avatar
Replacing the disks are easy once you get the thing apart. The problem is getting it apart...or should we say...putting it back together.
The early carriers had the shims on the outside of the unit between the quarter shaft housing and the case. Just be sure to save those and mark them per side. If you are going to tear it far enough apart to replace the disks, I would put in new bearings and seals.
Old 03-04-2018, 06:31 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
joyridin' is 100%.
John
Old 03-04-2018, 09:14 AM
Thanks, Guys
That's what I needed to know.
Jim
