Like Tree92Likes
  #41 (permalink)
Old 12-08-2019, 05:26 AM
MOTORHEAD's Avatar
Hi Craig ,
I assume this is a different car than the "big block street", ?
If so, you've got two glass bodies going onto original style frames at the same time, and throw in some light covers and header tanks for good measure ! Oh, I forgot to mention the trunk floor and gas tank !
You are a one man Cobra factory !!
"When Injustice becomes Law,
  #42 (permalink)
Old 12-08-2019, 05:31 AM
MOTORHEAD's Avatar
Are those Weber 48's or 58's ?
  #43 (permalink)
Old 12-09-2019, 12:46 AM
Gaz64's Avatar
I'd say they are 48s.
The largest bore you can get out of a 48 IDA is 51mm.
58s are from Gene Berg as one source.
  #44 (permalink)
Old 12-10-2019, 08:30 AM
cobrakiwi's Avatar
Mongoose930 nailed it, large fuel tank for the 427 car.
The webers in the picture are 48's.
jehammer1952 likes this.
  #45 (permalink)
Old 01-25-2020, 08:15 AM
cobrakiwi's Avatar
Time to rebuild a couple fuel pumps, crusty and rusty.
All stripped down ready for plating.
  #46 (permalink)
Old 02-17-2020, 01:02 PM
cobrakiwi's Avatar
Finished making a couple front diff mounts.
  #47 (permalink)
Old 03-03-2020, 04:57 PM
cobrakiwi's Avatar
Plating all done on the 2 SW fuel pumps and parts.
Now we just have to remember how to put them back together.
Also an old db10 relay cover got the plating treatment.
cobra, Buzz and jehammer1952 like this.
  #48 (permalink)
Old 03-03-2020, 08:07 PM
ERA 626's Avatar
very nice craig
  #49 (permalink)
Old 03-05-2020, 07:39 AM
cobrakiwi's Avatar
Pumps back together ready to mount in the car.
Buzz, Mongoose930 and jehammer1952 like this.
  #50 (permalink)
Old 03-05-2020, 01:36 PM
1795's Avatar
Craig,
As always, a work of art.
  #51 (permalink)
Old 03-05-2020, 03:21 PM
xb-60's Avatar
"Why? Because we can!" ....a great name for this thread.
I love it!
Please keep them coming
Glen
cobrakiwi likes this.
  #52 (permalink)
Old 03-14-2020, 04:59 AM
cobrakiwi's Avatar
The beginning of another task
  #53 (permalink)
Old 03-31-2020, 04:40 PM
cobrakiwi's Avatar
Picked up a few parts from the coaters today.
As usual outstanding quality.
  #54 (permalink)
Old 04-03-2020, 03:35 PM
cobrakiwi's Avatar
Recycling is sometimes needed, turning scrap into something we can use.
Old csx 4k firewall to these.
  #55 (permalink)
Old 04-09-2020, 08:48 AM
cobrakiwi's Avatar
Small block 5 bolt bell housing, I picked this deal up years ago thinking I may use it someday, I'm sure we all know how that goes.
It was missing the bottom cover so that's the project, make one.
This is the start of that job, after acquiring a couple of pictures of what the cover looks like (thanks Dan)
I made a pattern then broke out the plasma.
To my surprise my plasma cut through the 1/2 inch plate no problem.
Mongoose930, 1795 and jehammer1952 like this.
  #56 (permalink)
Old 04-09-2020, 09:02 AM
1795's Avatar
Wow, nice job Craig!
  #57 (permalink)
Old 04-09-2020, 11:32 AM
I take it you more work to do to that so the flywheel will fit?
  #58 (permalink)
Old 04-10-2020, 04:16 AM
cobrakiwi's Avatar
Thanks Jim
Yes still a bit of work ahead before we can use this bell, the lower cover has to be made to fit this.
  #59 (permalink)
Old 04-12-2020, 02:39 PM
cobrakiwi's Avatar
Upon further inspection of this bell I noticed the gearbox locating hole just did not look right.
Sure enough it had been taken to with a grinder or some other type of hand tool.
Looks like the hole had been opened up to take the large toploader/tko size bearing retainer from the t10 size..
Not good, now how to fix?
After sleeping on it and coffee in the morning I came up with an idea, why not machine the hole out to take a modern quicktime bellhousing insert?
First make a jig up to locate the bell were it should be for machining. To do this I made a fixture up using my good ford bellhousing.
Center the ford bell in the bridgeport then swap out the damaged bell.
  #60 (permalink)
Old 04-12-2020, 03:03 PM
cobrakiwi's Avatar
Next, cut the center to fit the quicktime insert, this went great but I noticed the cutter hitting the 12 o'clock area first and taking a bit to cut the entire 360 degrees.
After cutting the center, I checked the gearbox side surface and sure enough it was low at the 6 o'clock.
The fix, lock it down in the bridgeport and cut the gearbox side surface. Took a .040 cut to get it to where I am happy with it.
You can see by the blue paint it is still a little low at the 6 o'clock, but good enough.
This problem was not disclosed too me when I purchased the thing, but am very happy to be able to fix and save it.
This was a fun sunday afternoon project.
