Like Tree92Likes
  #61 (permalink)
Old 04-12-2020, 06:32 PM
1795's Avatar
Man, it sure is nice to have a workshop that has all the tools that you need. I would have had to send things out to multiple people for machining and welding. Nice work saving that bell housing Craig.
  #62 (permalink)
Old 04-12-2020, 07:39 PM
xb-60's Avatar
Originally Posted by cobrakiwi View Post
....Not good, now how to fix?
After sleeping on it and coffee in the morning I came up with an idea....
Nice job Craig.
So many times the solution to a problem isn't immediately obvious. Sleeping on it and with your subconscious working on it, it's quite amazing how often we can come up with novel and satisfying solutions when we had thought that the problems were insurmountable.
Cheers!
Glen
Tommy and jolsen42 like this.
  #63 (permalink)
Old 04-13-2020, 06:06 AM
cobrakiwi's Avatar
Thanks, yes it does help to have the tools available to tackle these types of jobs.
Glen
It's funny I find myself thinking way to much about this stuff late at night / early mornings.
  #64 (permalink)
Old 04-13-2020, 10:57 AM
Cobra Make, Engine: NAF 427
Great job on restoring those SW240A fuel pumps Craig. Love the look of those old pumps.
Why. Because we can! As you may know from some old posts of mine, I took two old SW240A pumps, gutted them, bored them out, and put two modern in-line electric fuel pumps inside.
Restored them to look period correct.
Had fun doing it and they work just fine.
Greg
  #65 (permalink)
Old 04-13-2020, 01:30 PM
cobrakiwi's Avatar
Greg
Thanks Greg.
I do remember your post about your fuel pumps.
As you know it takes a lot to refurbish these things.
I just got a few more in to do as well.
  #66 (permalink)
Old 04-14-2020, 04:18 AM
cobrakiwi's Avatar
Now back to the lower cover, cut out some more shapes with the plasma cutter, lots of grinding then some bending, then some welding and we came up with this.
Looks like it might just work.
I will set the bellhousing up on an engine and check everything and if it passes the test it will go to the powder coaters.
Anybody out there have a 5 bolt block plate they can part with?
  #67 (permalink)
Old 04-23-2020, 09:01 PM
Looks like it came out real good. Narrow bolt pattern T10's had a smaller front bearing retainer pre 65. 65 and later T10 had a bigger front bearing retainer and the 2 bolt patterns. At one time I had a scattershield for a 5 bolt engine that had both wide and narrow trans bolt patterns also had a ring so both bearing retainers would work.
  #68 (permalink)
Old 04-25-2020, 06:21 AM
cobrakiwi's Avatar
thanks, I think it turned out nice, always good to be able to save an old part and put it back into service.
  #69 (permalink)
Old 07-22-2020, 07:39 AM
cobrakiwi's Avatar
We need a few sets of rear brake ducts for our 427 cars,
decided to make them out of aluminum.
Ready for powder coating.
  #70 (permalink)
Old 07-22-2020, 07:51 AM
Coooooool!
Greg
  #71 (permalink)
Old 07-28-2020, 09:45 AM
cobrakiwi's Avatar
Thanks Greg
Rear brake ducts ready to install.
  #72 (permalink)
Old 07-28-2020, 10:22 AM
1795's Avatar
Craig,
They look great. Are you planning on adding any ducting to either the front or rear brake cooling ducts, or will you be using them just for some directional airflow?
  #73 (permalink)
Old 07-29-2020, 06:02 AM
cobrakiwi's Avatar
Craig,
Hey Jim
Installed for directional air flow at this stage.
  #74 (permalink)
Old 09-12-2020, 11:31 AM
cobrakiwi's Avatar
Had a request for some 289 lower control arms.
These ones will have rod ends on the pickup points so they will be adjustable.
Big thanks to Jeff G for a couple measurements.
AndrewB, LMH and A/S65 like this.
  #75 (permalink)
Old 09-13-2020, 10:47 AM
cobrakiwi's Avatar
Finished up my pet bellhousing project.
Picked up a block plate off flebay, filled the two lower corners, next up powder coating.
rodneym likes this.
  #76 (permalink)
Old 09-30-2020, 06:54 AM
cobrakiwi's Avatar
289 control arms back from coating, as usual fantastic job with the coating.
  #77 (permalink)
Old 12-09-2020, 09:19 AM
cobrakiwi's Avatar
Ready for chrome plating.
Any suggestions for a good plating company?
  #78 (permalink)
Old 12-09-2020, 09:59 AM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Very cool. What are you going to use for lenses? Will you be making your own bulb carrier or will these fit on an off the shelf lamp housing?
  #79 (permalink)
Old 12-09-2020, 10:01 AM
I'm in for a set!!
  #80 (permalink)
Old 12-09-2020, 04:18 PM
ERA 626's Avatar
Craig, I sent you a PM I need your help making a custom header tank for my CSX car... can you email me your contact info please so I can send photos... mikelagrone@me.com
