Like Tree1Likes
  • 1 Post By bobcowan
Old 03-31-2018, 10:15 PM
Cobra Make, Engine: Unique Motorcars, 428 big block
Default Bolts on non-adjustable seats
The carriage bolts spin in the wood seat base. Previous owner moved them to new holes to no avail. What is the trick to prevent them from spinning?
Old 04-01-2018, 04:16 AM
Ron61's Avatar
I don't know if you have enough wood to do this but one thing would be to counter sink the bolt heads. If not that, then got some good glue and glue the heads to the wood and let it set until it is hard. If that doesn't work, take a small piece of steel and bore a hole through it that the bolt can go through and then weld the bolt head to that and fasten the steel strip to the wood with small screws.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 04-01-2018, 08:01 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
I marked the places where I wanted holes then took the wooden bases out, drilled holes, and installed t-nuts made for wood so the bolts come in through the bottom. The covers are just stapled on; easy to R&R. Make SURE before you drill your holes through the floor plates that the seats will be angled properly and, on the passenger side, will leave enough room for an E-brake handle should you decide to go that way. If you screw up the seat base bad enough you can fix it with a new piece of wood; other things, not so much.
Bill
Old 04-01-2018, 08:34 AM
bobcowan's Avatar
Use a small strip of 1/8" steel, and weld two bolt heads together. Don;t have to take anything apart, and would take <30 minutes.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 04-01-2018, 08:47 AM
Thanks Ron, Bill and Bob for the suggestions. The t nuts sound like the best solution for me. I don’t have a welder. Will make a trip to the hardware this week.
Old 04-03-2018, 08:07 PM
bobcowan's Avatar
Well. I think you now have the perfect excuse for buying one!
FB54DM likes this.
.boB "Iron Man"
Old 04-03-2018, 10:38 PM
40k Later's Avatar
Cut a slot into the bottom of the bolt and use a regular screwdriver to hold the bolt while you tighten the nut with a wrench
Old 04-04-2018, 08:18 PM
Bill, The t nuts worked perfectly and look like a professional installation. Hard to believe gorilla tape was being used to keep the bolts from turning, which doesn’t work. Thanks again for the tip.
