November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree8Likes
  • 5 Post By HTM101
  • 1 Post By cobrakiwi
  • 1 Post By ScratchBuilder
  • 1 Post By SFSDFGT
Old 04-15-2018, 11:59 AM
Default Another Craig Coombe Remedy
Some years ago a fella called me, said he had built a 42 gallon competition fuel tank that fit my Hi-Tech Cobra, and offered it for sale. I said great, and its been in my car since.
Overall the tank has been fine, yet the tank's fill neck was originally mis-located and angled incorrectly. I contacted the seller and provided him with the offset measurement. He fabricated a Z-shaped adapter that allowed the connection between the tank neck and the upper fill neck. It worked, but filling the car required cloth towels wrapped around the outside fill, correct positioning of the gas nozzle, a steady hand and a relatively slow fill. Frequently I was splashed with a little gasoline blow-back if I moved the nozzle a bit during the fill process as the escaping air was in conflict with the in-coming gas. The tank is vented on the opposite end.
Recently I asked Craig Coombe if he would modify the tank neck and the upper fuel filler neck so incoming gas had a straighter shot as it entered the tank. Several days ago he made the modification and I'm certain the prior gasoline fill issue has been eliminated.
The first photo shows the original Z-shaped adapter. What isn't visible is the original tank fill neck location. That old neck was cut off and the hole was patched with a weld-on plate. The old Z-adapter is photographed sitting on the new tank neck that Craig fabricated and properly located it on the tank. I have not shown the rubber hose that connects the two tubes, for clarity of the alloy pieces.
The second photo is of the upper fuel fill neck that Craig also modified, and is stacked on the new tank neck. The resulting matched components provide a proper angle for fueling. Thanks Craig for meeting my need.
David
[IMG][/IMG]
[IMG][/IMG]
1985 CCX, LMH, Mongoose930 and 2 others like this.
Old 04-16-2018, 03:07 AM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
Thanks David,
It is always a pleasure to work on your cobra, I know it won't take you long to get the tank back in the car for a test.
Hopefully we have that problem behind us!
1985 CCX likes this.
Old 04-17-2018, 06:40 PM
Cobra Make, Engine: Scratch Built with 482 FE
Great work Craig! Functional and it looks better too��
SB
cobrakiwi likes this.
Old 04-17-2018, 08:23 PM
Cobra Make, Engine: CSX 4145, aluminum body and Shelby aluminum FE stroker
Craig built me a beautiful tank to replace the fuel cell in my car. Good stuff!
Old 04-18-2018, 06:16 AM
Craig is a busy man, so I tried to minimize the impact to his existing projects. I had previously removed the tank from my car, and had also removed the existing fill neck. When I arrived at his shop, he took a few measurements and cobbled the needed retro-fit and sent me on my way.
A pleasure to do Cobra business with.
David
Old 04-18-2018, 10:41 AM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Looking good David. Craig will be starting on my comp tank very soon!!!
Old 04-18-2018, 03:32 PM
Hey Kevin, thank you.
I've stood beside your alloy car several times now while visiting with Craig. Each time I see it I'm at a loss for words. When its completed, it certainly will be everything you've hoped for. It's such a stand-alone creation. I like it.
David
Old 04-20-2018, 12:02 AM
1985 CCX's Avatar
Awesome Criag
