Old 07-24-2018, 11:41 AM
Jim Coleman's Avatar
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Default Factory Five Side Pipes Plate Needed
Bought a new set of Factory Five side pipes.
I also bought a new set of stainless 460 shorty hugger headers, and would like to build my own J pipes to hook the headers up to the side pipes. I've seen the factory five J pipes with the special cut plate and a hole in the center, but
they won't work with the shorty headers.
Does anyone make just the plate, or will I have to buy some plate and cut
one out. If I do that, what thickness should I get ?
Thanks,
Jim
Old 07-25-2018, 06:07 PM
Dwight's Avatar
Smile
I bought some plate and used a hole saw and drill press. Very easy to do.
I think 5/16 plate is better. You will have to grind or file the plates flat after you weld in the tubes.
Dwight
Old 07-25-2018, 07:42 PM
Dwight,
How did you cut out the 4 pipe block off pattern ?
Thanks,
Jim
Old 07-25-2018, 07:50 PM
Dwight's Avatar
Smile
Not sure I understand your question.
Do you a picture of the pipes?
Old 07-25-2018, 07:52 PM
cycleguy55's Avatar
Thanks,
Jim
Have you contacted FFR? I'd be shocked if they haven't dealt with this previously.
Brian
Old 07-26-2018, 07:16 PM
Cobra Make, Engine: FFR, 302 EFI
Send a message via MSN to Bilt@home Send a message via Yahoo to Bilt@home
Talk to Breeze , they make shims for the ffr sidepipes.
Where are you located Jim?
Walt
Old 07-26-2018, 08:09 PM
I am in Waco, Texas 100 miles south of Dallas.
I'll contact Breeze and FFR.
My pipes have a "cloverleaf" (4 pipes) pattern.
Thanks,
Jim
Old 07-27-2018, 03:45 PM
cycleguy55's Avatar
Thanks,
Jim
I take it you're looking for a plate that matches up with this gasket:
Brian
Old 07-28-2018, 10:12 AM
Brian,
That's what I'm looking for, except it only has one hole in the center.
I may have to cut it out with my plasma cutter, found some 5/16 stainless at my supplier.
Thanks,
Jim
Display Modes
