Old 08-01-2018, 01:07 PM
AC Ventura's Avatar
Cobra Make, Engine: AC Cars Limited, 302 EFI
Default Engine mounts: Robert Pond alloy block
Hi guys,
Would anybody like to share the mounts they are using with the above block?
As you may know it has 4 x 7/16 tapped holes each side. I bought the flat rectangular 2241 & 2240 3 hole mounts but they don’t fit. Plus they are stepped and the machining is flat.
I know from one respondent that a custom longitudinal bush type arrangement is available, but not sure how that gonna work when I have lift under the bellhousing to slide the TKO in.
Im sure this is a well trodden path would be more than grateful for some real life pix and recommendations.
Old 08-01-2018, 01:37 PM
We currently use 2-bolt mounts, 31-2222 and 31-2223 on our Pond installations. It is stepped also. I didn't do the installation, so we may have had to shim it on that block. On our very early cars, we used the 3-bolt ones that you have, but never had to shim for the original iron FE block. (The stands on the chassis are not the same between the 2-bolt and 3-bolt mounts.)
Old 08-01-2018, 02:17 PM
RockBit's Avatar
Cobra Make, Engine: ERA #812 427/482 FE
I used the 31-2222 / 31-2223 mounts for my Pond aluminum FE in an ERA. I did not need to use shims, and have had no issues. I can raise the back of the block when installing or removing the transmission.
Sorry, but I don’t have good pictures.
Chris
Old 08-01-2018, 04:38 PM
jwoodard's Avatar
Thumbs up
I used polyurethane mounts from Craig's Cobras on my Genesis block. Should be fine for the Pond block as well. Here's a link: https://www.craigscobras.com/parts/mounts/index.htm
Jim Woodard
Old 08-05-2018, 09:35 AM
Varmit's Avatar
Cobra Make, Engine: Superformance#2352/Aluminum SO/490 c.i. 650 h.p. 605 tq.
That's what I used on my Pond 482
The Cannons don't thunder, there's nothing to plunder, I'm an over forty victim of fate
