Like Tree19Likes
  #21 (permalink)
Old 09-19-2018, 02:10 PM
dallas_'s Avatar
Bill,
I would try that. My Webers were happiest at 36 degrees total advance.
Bill D likes this.
  #22 (permalink)
Old 09-19-2018, 06:02 PM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Yep, 36 degrees total. If you get detonation back the timing off until the detonation is gone. With aluminum heads you should be good though.
Bill D likes this.
  #23 (permalink)
Old 09-19-2018, 06:56 PM
CC Member / Sponsor
I would try experimenting with getting your advance in sooner. You might also want to cut down your total mechanical advance, so you can run more initial advance. You might be surprised at how much better your engine can run.
Bill D likes this.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
  #24 (permalink)
Old 09-19-2018, 10:48 PM
The sooner your advance kicks in the happier your engine will be. You want to achieve total advance as soon as possible, 36 degrees total is the number you want to see.
I can see what Tom is trying to accomplish and on a big block that might work well where you are using less RPM but you will be running into detonation issues if you advance the static timing and do not limit your total mechanical advance in some way so that it does not go higher than 36 degrees total. This would require reconfiguring the advance window on the mechanical advance mechanism so that it limits your total advance.
Bill D likes this.
  #25 (permalink)
Old 09-24-2018, 04:43 PM
Bill D's Avatar
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Ok. New exhaust system in. Quieter and deeper. Base timing in at 16 deg with 36 total at 2500 rpm. Carbs all synced. New plugs that don’t hotbthe piston domes. Whew! Still have to design, fab and install muffler hangers . But getting closer to first drive
0CDB2929 8720 4FC2 81DD 3A6664B4526F - Sendvid
Gaz64 likes this.
  #26 (permalink)
Old 09-24-2018, 05:24 PM
1795's Avatar
Sounds smooth Bill. I am thinking that I might have to go without mufflers as I keep on hitting the mufflers on the corners and loosening the exhaust pipes. The thought of no mufflers makes my ears hurt in anticipation.
You are getting close. Keep up the good work.
Bill D likes this.
  #27 (permalink)
Old 09-24-2018, 07:16 PM
Man it does sound nice. Good work!
jolsen42 and Bill D like this.
Display Modes
