16Likes
12-27-2018, 11:42 AM
Originally Posted by patrickt
A Cobra is not normal. She'll get used to it.
Oh she knows I never do anything "normal". I have a 13' boat that runs over 100mph.
12-27-2018, 01:44 PM
Mr D,
This may be of some assistance in locating the proper mounting points, particularly for shoulder belts: https://www.impactraceproducts.com/r...tFAQ_a/248.htm
For a good cross-section of technically correct mounting info, you could find similar advice on Simpson, G-Force etc web sites.
Hope this helps,
Tom
12-27-2018, 03:15 PM
Cobra Make, Engine: ERA#375, FE 428, 1966 block, built by Jim Coleman Racing Engines, Stratford, CT
Over time, you will learn, as most of us have, that asking your wife about her opinion on the minutia items in, on and under the Cobra is not particularly the best idea.
Her mind will keep track of the "Cha Ching-ing" and then she will come to the realization that you are obsessed more, (and are spending more) on the Cobra than on her. That is not a good thing.
So, do NOT ask her about brands of oil, best filter, Will the K&N Extream Top look good, or how do you like the appearance of those new Avon tires....
Ehhh... at times it is best to take the quiet route....
After all.... She let you have the Cobra.... so she thinks.... ;-)
PS: Do NOT show her this thread.
PPS: This advice is also sound with your collection of Snap-On Tools, Guns, Cameras, Sound Systems, Stocks, Airplanes and any other such items many of which most of us "dabble in".
ERA 375 - former Clubcobra ID REDSC400
TESLA P90D is my daily driver
12-27-2018, 03:30 PM
NV
I found that with all things automotive hobby it was "easier to ask forgiveness than it is to get permission" (with regards to Adm. Grace Hopper)
CSX4005LA
12-28-2018, 09:11 AM
She has horses so there's never any discussion about expensive hobbies.
07-18-2019, 01:06 AM
FS
Cobra Make, Engine: Backdraft RT3
Originally Posted by twobjshelbys
Reviving old thread. There has been a lot of talk about the roll bar cross members from Finishline. They offer them in two mounting sizes, 1 1/2" and 2". The roll bars on the Backdraft is 42mm in diameter (see attached pic of the vernier measurement). Would the 2" mounting option fit the Backdraft, bearing in mind that the mounts have a rubber insert as well...? Finishline has not yet responded to the emailed request.
07-18-2019, 03:51 AM
SA
The "2 inch mounting option" would be somewhat bigger than 2" in diameter as it needs to accommodate the rubber sleeves as well.
I think you would be disappointed if you bought that cross bar because the diameter would be way too big to fit your roll-over bar.
Glen
07-18-2019, 11:09 AM
Lomdel,
The Early BDRs (like mine) came factory equipped with the Crossbar.
My Rollbar measures the same as yours. 42mm / 1.62 inch.
I'd contact the Backdraft Factory there in ZA as they can probably source one for you or point to a vendor.
07-18-2019, 01:22 PM
My early Contemporary also has the crossbar mount. Works just fine for me... Matter of fact, I believe if you look at Ken Miles car in the early days, you will see that his race car had a crossbar harness mount...
Dan in Arizona
CCX3209
07-18-2019, 05:59 PM
I'd class that tube as 1 5/8.
07-19-2019, 04:47 PM
One thing you need to know. Racing organizations have outlawed 3” wide lap belts because they don’t fit low on the pelvis well. Get 2” lap belts.
07-22-2019, 06:49 AM
FS
Backdraft factory in SA does not stock that part anymore. If the Finishline 1 1/5" clamps are a bit bigger to accommodate the rubber insert, it should fit the 1 5/8" size of the Backdraft rollbars just fine. However, Finishline does not have stock of the 1 1/5" ones and they do not respond to emails. Maybe one of you guys have an inside line to Taylor at Finishline to ask when will they get stock again...?
Has anyone dealt with these guys yet? https://www.pythonvehicles.com/interior
07-23-2019, 01:09 AM
FS
I hope you guys don't mind, but I would like to continue this conversation in another more aptly named thread : Roll bar cross member and 5/6pt belts . The thread title would generate more focused response, I hope. Please join me over there...
07-23-2019, 12:40 PM
Try Cobrarestorers.com They have several types and styles of belts and anchors.
Dan in Arizona
CCX3209
