Like Tree3Likes
  • 2 Post By HTM101
  • 1 Post By Blas
Old 12-27-2018, 05:55 PM
Jim Coleman's Avatar
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Default Best Heat Shield For Foot Boxes ?
The headers on my Arntz are within 2" of the footboxes where the pedals are located. I don't want Cobra hot foot. The original Arntz setup was a shield that was set off from the footboxes where air could cool the backside of the shield.
With today's technology there's bound to be a better way...
Suggestions ?
Old 12-28-2018, 01:41 PM
Cobra Make, Engine: ERA#375, FE 428, 1966 block, built by Jim Coleman Racing Engines, Stratford, CT
Jim: What are Pontoons? Do you mean the foot boxes? If so, there is a heat shield material with silver foil on one side and an adhesive on the other. As I recall from my build, this was sold in rolls. The silver foil was/is kind of waffle dimpled. My supply was from ERA. However I suspect that this is a rather ubiquitous material and is available from many sources of supply.
Additionally, my ERA has be fitted with the optional triangular wire vents which allows warm air from the header collector area to pass into the front wheel wells and relieves air build up in the engine compartment at high speeds. Also, optional ducting from the cold air ducts is aimed at the front disc calipers and rotor as well via a 3 1/2 inch "y" connector. This promotes air flow over the front disc brake assemblies. This was a common practice and there are some very old photos of this setup in the Getty photo archives particularly with the #7 427 SC race car.
ERA 375 - former Clubcobra ID REDSC400
TESLA P90D is my daily driver
Old 12-28-2018, 02:26 PM
Neutral
I think Arntz called them pontoons, but they are better described as foot boxes. I changed the post.
Old 12-28-2018, 03:16 PM
Ok, makes sense Jim. I think the product is called Thermo-Tec adhesive heat shield. It is sold in sheets of 12" by 24" perhaps even larger. I see it on Summit, Jegs, etc. You may want to contact Pegasus racing to see if they have something else that they could suggest.
Thermo Tec makes quite a few products for heat protection, here is their link... https://www.thermotec.com/products/h...and-protection
Old 12-28-2018, 03:42 PM
Suggestions ?
You've got options. The "waffle steel" is good stuff, so is Thermaflect, and several others. They even have "stealth barriers" now. This is one of the many sites offering automotive thermal barriers: https://www.heatshieldproducts.com/a...ermal-barriers
Old 12-28-2018, 03:56 PM
joyridin''s Avatar
This is what I used on the inside and outside of the footbox.
Floor & Tunnel Shield II - Extreme Heat Shield | Design Engineering Inc
Old 12-28-2018, 07:20 PM
Thanks, guys
I'll get in touch with these folks and get something done.
Old 12-30-2018, 07:37 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Originally Posted by 66AC View Post
..... Getty photo archives particularly with the #7 427 SC race car.
Could you please send a pointer directly to these wheel well vent photos? I would like to see some variations of what has been done already if anyone has them installed.
Winter project.... thanks
Blas
SPFWiringDiagrams@Comcast.net
Old 12-31-2018, 06:30 AM
Blas
Sure, I did a Google search of R Beazell Shelby Cobra driver and you will see in the Images a slew of photos, The Black and White up on jack stands of #7 is the one you want...
https://www.gettyimages.com/photos/s...shelby%20cobra
Old 12-31-2018, 08:25 AM
Blas
Blas,
Here are several shots of the wheel well mods I made.
Blas and 66AC like this.
Old 01-03-2019, 08:15 AM
Blas's Avatar
Thanks to all.... looks like a good winter project. Does it add additional dust etc to the engine compartment in anyone’s opinion? I find the #7 up on jack stands photo but see no wheel well vents in that photo just the side vent. The link posted take me to some weird advertisement site.
Blas
Old 01-03-2019, 09:36 AM
Blas
It does not add a noticeable amount of dust to the engine compartment. But what you will find is that at stoplights, when your fans kick on, is that you can feel the heat billow out from the wheel well and down along the side of the car. Here's a pic of mine:
Old 01-03-2019, 02:57 PM
Blas
Possibly a tad bit more dust, as I opened a large area. I anticipated more dust and debris than actually occurs.
The modification has been a positive gain in heat management during slow speed driving.
Old 01-03-2019, 03:45 PM
Blas
Do you see the round hose coming in from the upper part of the wheel well? That is probably connected to a "Y" from the fresh air system in the front nacelle. So it is an air introduction hose per se, not a vent. It is aimed at the top of the caliper and rotor.
Old 01-03-2019, 08:08 PM
Blas's Avatar
66AC - it was the screen vent on the rear sections of the wheel well I was referring to in my post. But thank you for your time and effort.
HTM101 - very nicely done screen and surround. You should sell those things I will have difficulty in matching the same quality in what I fabricate...well done!
Blas
HTM101 likes this.
