Like Tree3Likes
  • 2 Post By hauss
  • 1 Post By Ron61
Old 02-26-2019, 12:04 PM
hauss's Avatar
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Default Things to watch for
Whenever I take my backdraft out , I do a walk around. In performing my task I noticed a scoring on my rear drivers side rotor. Thinking it was a pebble from some asphalt I went for a spirited drive.my car snap steered so bad it raised the hair on my neck. You could say my spidey senses were tingling.I pulled off the rear wheel witch took a 911 tool way past the 25lbs limit and 50 blows with a 6 lbs lead hammer! I removed the caliper and found no problems. I rocked the rotor from side to side and noticed a lot of movement. So I decided to remove the center cap and noticed a bolt laying inside.It came out of the axel. I was able to reinstall the bolt to 150 ft lbs of torque . I have the new style axles from backdraft .The car only has 3000 miles on it,so I believe it was not tightened correctly . I still love my car just want people to be safe. The only thing stopping my wheel from coming off was the caliper.Hope this helps my fellow cobra owners. Hauss.
35olds and desgros@vtlink. like this.
Old 02-26-2019, 08:21 PM
RUFdriver's Avatar
Cobra Make, Engine: UCC GT 427
That’s very scary, did you notify Backdraft ?
Old 02-26-2019, 11:52 PM
hauss's Avatar
No I did not I am the 3rd owner car is a 2012. I don"t even know who I would contact.
Old 02-27-2019, 03:04 AM
Ron61's Avatar
Glad that you found it before something bad happened. I always do a check of my car after driving it and check all bolts to be sure they are still tight. The vibration and hard driving tend to cause bolts to loosen.
35olds likes this.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 02-27-2019, 07:32 AM
hauss's Avatar
The problem with my situation only showed up when the car was in the air.So I would recommend folks to jack up rear of car and check rear tires for any unnatural movement .
Old 02-27-2019, 07:35 AM
hauss's Avatar
After this one I"m going to do both before and after.
Old 03-01-2019, 01:24 PM
t walgamuth's Avatar
I had a similar thing happen on my Formula Ford autocross car about eight years ago. The hub had cracked but things were still together. I did not notice anything unusual until the wheel came off. Like in your case the caliper on the disc had been holding on and did so until the center came out of the rotor... and I spun to a stop.
The hub had actually fractured and came out in five pieces.
No fun!
Old 03-01-2019, 03:01 PM
hauss's Avatar
No fun!
What are you saying? I have a cracked hub ? I did not notice anything I retorqued to 150 ft.lbs.
Old 03-03-2019, 09:36 AM
I'm not saying anything. Sorry I did not mean to set off an alarm....just reminiscing.
Your comment about the caliper holding it on sparked the memory which I shared.
Old 03-03-2019, 10:49 AM
hauss's Avatar
FYI you scared the Crap out of me so I went back and rechecked everything all is good.
Old 03-03-2019, 11:03 AM
Sorry, I just get carried away thinking how great my stories are.
Glad everything is good.
