Like Tree1Likes
  • 1 Post By ALF
Old 08-13-2019, 08:19 PM
Jim Coleman's Avatar
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Default Help With Cobra Tail Light Wiring Needed
I am in process of installing a wiring harness in my Arntz.
The tail light assemblies are one piece units and only have 2 wires.
The wire colors are green with a white stripe and yellow with a white stripe.
Since there are 3 wires going to each tail light -- brake, turn signal & park -
how are they wired ?
Old 08-14-2019, 12:04 AM
ALF's Avatar
ALF ALF is offline
Hi Jim
If you use the DB 10 relais and the Lucas L542 lights BREAK and TURN SIGNAL is the same wire.
- park light (5W on two wire bulp)
- break/turn signal (21W on two wire bulp)
- ground
Alfa02 likes this.
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
Old 08-14-2019, 02:12 AM
Thanks, Alf-
Which wire is the brake lights/turn signal ?
Old 08-14-2019, 05:05 AM
Originally Posted by Jim Coleman View Post
Thanks, Alf-
I wouldn't count on any consistency relating colors to filaments.
Turn the parking lights on and connect the live lead at the rear light to the wire of the dimmer filament.
Old 08-14-2019, 04:20 PM
What I did was install removable bullet connectors so I can change them around if needed after the harness is completely installed.
Old 08-20-2019, 03:57 AM
ALF's Avatar
ALF ALF is offline
I've the 289 wire colors in use.
Red = RH/ LH Tail Lamp
White and Puple = LH Stop Lamp
White and Brown = RH Stop Lamp
Black = Ground
Thanks, Alf-
Old 08-24-2019, 04:06 AM
Thanks, again Alf
