| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
1Likes
Post By strictlypersonl
11-13-2019, 08:43 AM
Club Cobra Member
ca
Cobra Make, Engine: NAF 427
Shortened drive shaft
Does anyone have a shortened driveshaft for sale?
PM me or e-mail me with details.
Greg
11-13-2019, 05:55 PM
CT
Greg
You need to supply more details about your transmission and rear end. On the ERA, there are at least 4 variations, and those are for the "normal" configurations.
11-13-2019, 09:09 PM
CA
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
contact Modern Drive Line, they can make you one.
11-14-2019, 06:13 AM
Or Machine Service, Inc. in Green Bay, WI. They made mine.
11-14-2019, 08:43 AM
Club Cobra Member
ca
Thanks guys for your input. I'll contact those suppliers if I can't find one for sale.
My requirement is far from normal. Corvette C3 diff and Ford C6 trans.
With the various hybrid universal joints available, just about anything can be adapted.
Not sure of the length yet. So it most likely will be custom.
Greg
11-29-2019, 04:17 PM
UK
Cobra Make, Engine: AC Cars Limited, 302 EFI
Most important part is that the diff and trans centrelines are parallel. They can be offset up to about 6 degrees, but must lie in the same plane. As others have indicated, any driveshaft shop can make up a special to fit and not hugely expensive.
11-29-2019, 07:36 PM
CA
center line meaning north and south Up/down) or east west (left right)?
11-30-2019, 04:51 AM
CT
Both. The object is to have the transmission axis parallel to the differential axis. Vertical and horizontal offsets are equivalent in driveshaft's view. The most important thing is that the maximum angle of the joint is not exceeded during wheel travel.
11-30-2019, 11:41 AM
CA
In IRS applications the diff does not move so wheel travel does not come into play?
11-30-2019, 02:19 PM
Cobra Make, Engine: SPF#0760
Edited version: (fiberglass = carbon fiber)
Anyone ever look into the “carbon fiber” driveshaft? Perhaps because it is so short a “carbon fiber” shaft would give no advantage?
SPFWiringDiagrams@Comcast.net
11-30-2019, 02:25 PM
Originally Posted by Blas
Anyone ever look into the fiberglass driveshaft? Perhaps because it is so short a fiberglass shaft would give no advantage? O
I prefer a rubber driveshaft. It stores energy up as it twists then it really cuts loose for added acceleration as it unwinds itself.
12-05-2019, 03:33 AM
QLD
I'm glad this reads as carbon fibre now, instead of fibreglass.
Gary
12-05-2019, 06:58 AM
CT
Correct.
