| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
2Likes
Post By xb-60
Post By LMH
03-19-2020, 03:41 AM
SA
Badge location on 289s
Saw a thread on covering the location of badge placement on the hood and trunk of 289 Cobras, but now can't find it.
Can anybody help?
Cheers!
Glen
03-19-2020, 06:48 PM
Senior CC Premier Member
WA
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
Can anybody help?
Cheers!
Glen
Hi Glen,
Below are a few, you may have readily found these too (some don't really offer too much), but just in case...Brent
"AC" badge vs. Cobra Snake badge??
Cobra deck emblem placement
Cobra Emblem
Cobra Emblem
Front emblem placement - SCOF /ERA no match
Badging
Badging
Emblem locations
Emblem locations
(PS: The long web addresses eventually resolved to the thread names, that's why they appear duplicated, I'll just leave it.)
03-19-2020, 09:03 PM
AZ
Can anybody help?
Cheers!
Glen
You know the FIA Team Cobras didn't use badges, right?
Alba gu brąth
03-20-2020, 07:50 PM
SA
Originally Posted by EM-0785
Thanks Brent. I already had the ERA information. Most of the information on those posts is relevant to 427 cars, but in the absence of anything specific to 289s, I'll use that info as a 'guide'.
Glen
03-20-2020, 08:00 PM
WA
Hi Glen,
Just curious...if you go into meditation mode for a bit can you remember any unique words or member handles on the thread you're looking for that might help narrow the search for it? Do you happen to recall how old or what year the thread was, or possibly what forum (Originality, Build Logs, etc.)? Are you confident it was on this site? Did you post in that thread? Brent
Reason: Forums
03-21-2020, 01:05 AM
WA
Glen,
(Really not trying to stalk you on this one, just love a good puzzle!  )
Here's one more intersting link that while not specifying location/placement, seems to speak to original 289 badges. I assume if you PM Dan Case or others on that thread they may have information for you?
AC Boot Badge
AC Boot Badge
Over and out for now...Brent
03-21-2020, 01:28 AM
SA
Hi Larry.
Yes, correct. No badges on factory FIA cars.
My car, though described as “289FIA 'English' spec.”, is loosely based on COB6008, not the Shelby FIA cars.
COB6008 was delivered from the AC factory as “a street car”….“with cut backdoors, wide flares and Halibrand wheels” (ref. Registry). It was, in effect, an English equivalent of an FIA car, and has an extensive racing history.
6008 wore an AC badge on the trunk and a Cobra badge on its nose, although I can’t verify from early pictures whether the Cobra badge was a factory fit by AC.
6008 wore “Powered by FORD” badges as well.
To my knowledge, the only FIA car that wore any badges at all is CSX2323, but after its resto in ’98, it didn’t have them. Most period shots of 2323 show it without badges.
Glen
note below on COB6008....AC trunk badge, Cobra nose badge and Powered by Ford badge
03-21-2020, 01:36 AM
SA
Hi Glen,
Frustrating, this
All I recall is that I thought the information will be helpful for me, but didn't copy it and save it as I normally would
Glen
03-21-2020, 01:37 AM
SA
Glen,
AC Boot Badge
AC Boot Badge
Good point Brett. I'll ask Dan.
03-21-2020, 11:16 AM
WA
Glen,
When talking with Tom (Alfa02) today he thought you might also try ALF on this site. ALF has had multiple 289 (FIA) cars and per Tom is pretty knowledgable on this stuff. I know they've also talked 289 badging several times themselves.
Fwiw...Brent
03-21-2020, 07:35 PM
SA
I asked Dan Case. He has "never made a study of those details".
I think I'll use ERA's 427 info and check to see if that suits my 289 application.
Glen
03-21-2020, 07:48 PM
SA
Another question...
Is it better to use the protrusions/studs on the badges to mount them, or remove them, and use double sided tape?
Here's some info from a 2003 post:
Originally Posted by Steve Kirkham
Back in the Jurassic era, when we restored Mustangs (even before we restored Shelby Mustangs), we'd always clip the mounting studs off the back of all emblems.
We'd carefully trim 3M emblem adhesive tape to fill the depressions in the back and have a uniformly flat surface. Then we'd stick the emblems to the car, lining them up by eye.
That way, we avoided drilling holes through our fresh paint. We also avoided problems with the posts being in the wrong place. Once we started that, the lack of headaches was refreshing.
We had no problems with emblems staying in place. The same cannot be said for our experiences with mounting posts.
....but I wouldn't mind other opinions while I consider what to do.
Glen
03-21-2020, 08:37 PM
AZ
I would much rather have emblems mechanically fastened to the body rather than use tape or glue. Changes in temperature, humidity, possibly water from rain, all could cause the emblem to fall off. And you know that going to happen when your driving, not sitting in the shop.
Alba gu brąth
03-22-2020, 02:35 AM
SA
Larry, what do you (or others) use to secure the studs? Circlips? Do you use anything between the paint surface and the underside of the badge/emblem?
The reason I am questioning the stud method of attachment is that if some light-fingered b@st@rd took a liking to them, the trunk and nose surfaces could be damaged.
Happened to me twice with my Alfa. There are some schmucks out there  ....even in little ol' Adelaide.
Cheers!
Glen
03-22-2020, 08:57 AM
AZ
I use a push nut. There are a few different styles but pretty much all work the same way.
Someone popping it off could damage the body, thats true but it's also true of glue or tape. When he takes out his pocket knife or screwdriver to pop it off, he's going to scratch it or dent the body around the emblem. Of course, he also better be a good runner if I see it happen!
Alba gu brąth
