Old 08-07-2020, 09:56 PM
xb-60's Avatar
Default SW fuel pressure gauge how much?
Any learned opinions on what you should pay for a 2⅝" Stewart Warner 0-10psi fuel pressure gauge?
This one needs refurbishing...
Cheers!
Glen
Old 08-08-2020, 05:02 AM
55312's Avatar
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
Look on Amazon, Summit or Jegs. They will be pennies apart. I bought one for water temp from Summit. Don't remember the cost but wasn't much.
Tim
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
Old 08-08-2020, 06:55 AM
LMH's Avatar
LMH LMH is offline
Watch this one and see what it sells for: https://www.ebay.com/itm/324249995321
Alba gu brąth
Old 08-08-2020, 10:29 AM
Does that have a capillary tube and bulb like my mechanical temp gauges? Or does it do it like my mechanical oil pressure gauge?
Old 08-08-2020, 08:30 PM
xb-60's Avatar
Tim
Tim, these SW fuel pressure gauges were used on Comp. 289's; I don't think they have been available new since maybe the 1970's
Glen
Old 08-08-2020, 08:32 PM
xb-60's Avatar
Thanks Larry. Will do
Old 08-08-2020, 08:49 PM
xb-60's Avatar
Pat, originally it would have a similar setup to a "mechanical" oil pressure gauge, with fuel all the way to the gauge.
It is now of course recognised as too dangerous to have a tube with high octane in it piped through to the back of the dash. Hence, present day fit would use an isolator mounted on/near the firewall, with - I think - water used from the isolator to the gauge.
Isolator would look something like this, with fuel to one side of the diaphragm and water from the other side to the gauge. Could be wrong about the water, but it would be something that obviously is not flammable Name:  Fuel pressure isolator.jpg
Glen
Old 08-09-2020, 05:29 AM
OK, that makes sense. I just hate fuel leaks. Especially if they're dripping on my knee.
Old 08-09-2020, 07:15 AM
Cobra Make, Engine: CSX4000, 427
Attachment 35050
Cheers!
Glen
I would just get it refurbished. There are multiple companies that refurbish gauges/ dashes. Unless you can find one already refurbished. If you buy another used one, it may the same or worse condition than yours.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 08-09-2020, 04:08 PM
Gaz64's Avatar
Glen
From Autometer's instructions for fuel pressure with isolator:
NOTE: Fluid leaking from system will cause gauge to read incorrectly. If leakage
occurs, fill isolator with solution of half water, half propylene glycol (antifreeze).
Gary
Old 08-09-2020, 05:30 PM
twobjshelbys's Avatar
My estimate is that rebuilding it (and shipping) will cost you more than a new one. Unless you're looking for authenticity, in which case you just want to leave it alone.
Tony
CSX4005LA
Old 08-09-2020, 05:34 PM
I guess for true authenticity, it needs to leak a little bit.
Old 08-09-2020, 11:54 PM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
These particular gauges have not been available new for decades. I have used one for years without issue.
Old 08-10-2020, 09:21 PM
xb-60's Avatar
I have my answer....that one sold for USD 78
Glen
