| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
06-11-2020, 07:16 AM
MI
Cobra Make, Engine: SPF Coupe #136, 427SR FI
Identify This Cobra
Hi Gang
Need your counsel.
The Cobra in the attached pictures was built 2 years ago.
I do not believe it is a Factory Five or a SPF. There is not a name/vin plate.
Any distinguishing "tells" that would lead to the brand of replica?
Thanks
Jeff
06-11-2020, 08:06 AM
CO
Looks like a Backdraft. What suspension does it have?
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
06-11-2020, 09:40 AM
CT
Unless Backdraft's design has changed, the engine is too far forward. The front suspension doesn't look the same too.
06-11-2020, 09:45 AM
FL
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
The SS round expansion tank and upper rad pipe scream BDR, but I see an upper front wishbone peeking thru on the pass side eng compartment and BDR uses BMW front struts. If it is BDR, the vin should be stamped on the crossmember the exp tank is mounted to.
Also, I see the pass door latch is the original type British latch assy. BDR uses a crappy latch from something non-automotive.
Could be very early BDR before changes That may have been made to cheaper parts to lower price.
If not BDR, I'll say Shell Valley ? B&B.
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
06-11-2020, 01:17 PM
Backdraft Racing Dealer
CT
Shell Valley is known to use the Backdraft Expansion Tanks. Wheel base and fender gaps look like the Cobra Tommy Lee drove to college on that reality show bomb and that was a SV.
What is the rear suspension?
06-11-2020, 01:28 PM
Ala
Cobra Make, Engine: Shell Valley, 408 Stroker
I own a Shell Valley and there's 3 things that look identical to my car. First the hood hinges are exactly like the ones on my car, second the door latches are the same also and third the fat 2" roll bar most other kit use an 1 7/8". So I'd say thats probably a Shell Valley.
06-11-2020, 07:33 PM
Cobra Make, Engine: Backdraft cobra FE big bock
I vote shell valley. My backdraft rollbar is thinner than that. I haven't seen a backdraft running a bar that thick.
06-11-2020, 07:42 PM
NJ
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Throttle linkage and steering column are not Backdraft. Column looks after market with the left side directional.
06-11-2020, 08:44 PM
SA
The steep angle on the rollover bar support and also the trim/surrounds for the rollover bar and the support bar suggest Shell Valley too.
06-11-2020, 08:58 PM
Ca
Cobra Make, Engine: Shell Valley w/BluePrint 408
The fiberglass inner fender panels, the squareness and position of the the upper passenger foot box, steering column mount, thicker (2 inch) roll are and lower front cross member all resemble my SV.
06-11-2020, 10:10 PM
IL
Cobra Make, Engine: Antique and Collectibles Autos, Inc.
Hi all, I have an Antique and Collectible Autos Cobra replica and I believe this is one of theirs. The radiator is titled forward. They also use the same hood hinges and door latches. The roll bar is 1.75". Checkout my album if you like.
06-12-2020, 11:43 AM
CA
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
shell valley
09-24-2020, 08:44 AM
Cobra Make, Engine: Shell Valley 428CJ with 427 Tunnel Port top side
Not the same as 2005 shell valley
Since a more recent build than mine it might be the redesigned shell valley after the merger with midstates.
My 2005 shell valley has the e-brake on top of the transmission tunnel and the hood support rod is mounted much further back and lower in the engine compartment.
09-24-2020, 11:15 AM
WA
If I were a betting man, and I am. Top of the list would be Shell Valley.
09-24-2020, 02:08 PM
SK
To my eyes the rear fenders look like FFR Mk3.
Brian
09-24-2020, 05:46 PM
SC
All the tells are there, I concur with those who labeled in a Shell Valley.
09-25-2020, 08:36 AM
Average Guy
IN
Cobra Make, Engine: red Shell Valley, white stripes
I concur
Looks a lot like my Shell Valley.
When I said I wanted to be somebody, I probably should have been more specific...
