Old 06-11-2020, 07:16 AM
Cobra Make, Engine: SPF Coupe #136, 427SR FI
Default Identify This Cobra
Hi Gang
Need your counsel.
The Cobra in the attached pictures was built 2 years ago.
I do not believe it is a Factory Five or a SPF. There is not a name/vin plate.
Any distinguishing "tells" that would lead to the brand of replica?
Jeff
Old 06-11-2020, 08:06 AM
bobcowan's Avatar
Looks like a Backdraft. What suspension does it have?
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 06-11-2020, 09:40 AM
Unless Backdraft's design has changed, the engine is too far forward. The front suspension doesn't look the same too.
Old 06-11-2020, 09:45 AM
MOTORHEAD's Avatar
The SS round expansion tank and upper rad pipe scream BDR, but I see an upper front wishbone peeking thru on the pass side eng compartment and BDR uses BMW front struts. If it is BDR, the vin should be stamped on the crossmember the exp tank is mounted to.
Also, I see the pass door latch is the original type British latch assy. BDR uses a crappy latch from something non-automotive.
Could be very early BDR before changes That may have been made to cheaper parts to lower price.
If not BDR, I'll say Shell Valley ? B&B.
"When Injustice becomes Law,
Old 06-11-2020, 01:17 PM
Cashburn's Avatar
Backdraft Racing Dealer
Shell Valley is known to use the Backdraft Expansion Tanks. Wheel base and fender gaps look like the Cobra Tommy Lee drove to college on that reality show bomb and that was a SV.
What is the rear suspension?
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 06-11-2020, 01:28 PM
67sn8ke's Avatar
Cobra Make, Engine: Shell Valley, 408 Stroker
I own a Shell Valley and there's 3 things that look identical to my car. First the hood hinges are exactly like the ones on my car, second the door latches are the same also and third the fat 2" roll bar most other kit use an 1 7/8". So I'd say thats probably a Shell Valley.
Old 06-11-2020, 07:33 PM
Cobra Make, Engine: Backdraft cobra FE big bock
I vote shell valley. My backdraft rollbar is thinner than that. I haven't seen a backdraft running a bar that thick.
Old 06-11-2020, 07:42 PM
FredG's Avatar
Throttle linkage and steering column are not Backdraft. Column looks after market with the left side directional.
Old 06-11-2020, 08:44 PM
xb-60's Avatar
The steep angle on the rollover bar support and also the trim/surrounds for the rollover bar and the support bar suggest Shell Valley too.
Old 06-11-2020, 08:58 PM
Cobra Make, Engine: Shell Valley w/BluePrint 408
The fiberglass inner fender panels, the squareness and position of the the upper passenger foot box, steering column mount, thicker (2 inch) roll are and lower front cross member all resemble my SV.
Old 06-11-2020, 10:10 PM
Cobra Make, Engine: Antique and Collectibles Autos, Inc.
Hi all, I have an Antique and Collectible Autos Cobra replica and I believe this is one of theirs. The radiator is titled forward. They also use the same hood hinges and door latches. The roll bar is 1.75". Checkout my album if you like.
Old 06-12-2020, 11:43 AM
ERA 626's Avatar
shell valley
Old 09-24-2020, 08:44 AM
Cobra Make, Engine: Shell Valley 428CJ with 427 Tunnel Port top side
Default Not the same as 2005 shell valley
Since a more recent build than mine it might be the redesigned shell valley after the merger with midstates.
My 2005 shell valley has the e-brake on top of the transmission tunnel and the hood support rod is mounted much further back and lower in the engine compartment.
Old 09-24-2020, 11:15 AM
Alfa02's Avatar
Gold Star Contributor
If I were a betting man, and I am. Top of the list would be Shell Valley.
Old 09-24-2020, 02:08 PM
cycleguy55's Avatar
To my eyes the rear fenders look like FFR Mk3.
Brian
Old 09-24-2020, 05:46 PM
mrmustang's Avatar
All the tells are there, I concur with those who labeled in a Shell Valley.
Old 09-25-2020, 08:36 AM
Average Guy
Default I concur
Looks a lot like my Shell Valley.
