| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
3Likes
2
Post By Mark IV
Post By hauss
07-12-2020, 03:30 AM
WC
Cobra Make, Engine: Shamrock
Anybody had Wheel Drive Pin Failure?
Following on from my thread re friction enhancers has anybody had failure of the drive pins despite proper clamping.
The question is asked to ascertain if 5 pins are inadequate and 6 pins are needed to guarantee non failure when spinners properly tight.
07-12-2020, 05:06 AM
IN
Cobra Make, Engine: ERA 838
I have never heard of pin failure.
Also, Indy champ cars have a similar set up with, I think, 6 pins.
Early Cobras had spline drive.
Pin failure is unlikely.
John
07-12-2020, 08:52 AM
Ca
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Original street configuration 260/289 Cobras used spline drive hubs, competition 260/289 Cobras used pin drive hubs with 6 pins per wheel.
07-12-2020, 09:06 AM
AZ
I did have an issue that my pins were too long for the depth of the holes in the wheel. Fortunately, I was able to figure out the problem after some minor hogging out of the holes. One of those weird things that really had me scratching my head.
Karlos
07-12-2020, 09:09 AM
VT
Cobra Make, Engine: ERA Slabside BRG 289
After owning a Lone Star and currently my ERA Slabside both with pin drive I've not experienced any problems or failures.
John
ERA #3010 Slabside 289 SB BRG
Reason: spelling
07-12-2020, 09:40 AM
CA
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
Had a 6 pin ERA for 17 years for 17 years no issues...
07-12-2020, 12:00 PM
MI
Cobra Make, Engine: FFR Challenge Car, RDI aluminum 427w
I've owned two Superformance cars and have experience with many other owners these were all 5-pin drive. Never a problem with properly installed pins breaking. Some of the cars ran track tires and 600-700 hp.
I've seen replacement pins that were not machined properly, others were too long or a bit short, but no issues.
One problem that does happen is owners don't remove the wheels periodically and have the wheels seize on the pins, silver anti-seize usually solves the problem. Then some don't get the spinners tightened properly, it does take a solid hit or two with a LEAD hammer and another hit after a few miles.
I wouldn't worry about 5 or 6 pins.
Jim
07-12-2020, 01:31 PM
With only 1400 lbs sitting on the back wheels, my old Yokos spin like they're on snow. I think I could get by on three pins, much less six.
07-12-2020, 04:22 PM
VT
Jim,
Speaking of lead hammers, a Snap On shot filled hammer works well lasting for many wheel changes with no distortion as with a traditional lead hammer.
John
07-12-2020, 04:40 PM
Originally Posted by desgros@vtlink.
Speaking of lead hammers, a Snap On shot filled hammer works well...
Trust me, if you're in your sixties, or seventies, and you still love working on your Cobra, taking those damn spinners off is often the roughest part of the job. Nothing beats an impact gun. I Can Remove My Spinners With One Finger
07-12-2020, 04:47 PM
AR
C2 Corvettes have also gotten along fine with 5-pin KO wheels for decades. I've never heard of a pin failure on one of them either and that's considering they weigh 500 - 700 lbs more than a Cobra and owners have been driving them hard with built motors all these years. And 4000 lb musclecars with modern built engines get along fine with 5-stud wheels still. Blow an axle or ring gear once in awhile, yes - but shearing wheel lugs is usually only an issue with over-torqued lug nuts and fractured lug nut studs.
07-12-2020, 04:56 PM
MI
Sorry, I don't think a dead blow hammer is the same as a proper lead hammer.
If you're worried about a scuff on spinners you should be using lugnuts.
And yes, I am occasionally harsh but I've also see wheels come off.
Jim
07-12-2020, 06:32 PM
Ca
I ONLY recommend a lead hammer for removing and installing knock-offs. I have never had a lead hammer damage either a knock-off or a wheel. If your knock-offs are Aluminum and seized on That is something completely different than normal.
07-12-2020, 07:04 PM
IN
I have a nice copper hammer that is good for knockoffs.
07-13-2020, 01:57 AM
WC
Talking about lead hammers - the local Cobra Hire firm with about 20 Cobras use a piece of 1m long 4X4 wood and a 4 pound hammer - works a treat and does no damage. Works well taking spinners on or off.
That's what I use now - much cheaper and easier to get htan lead hammer and easily fits in the boot/trunk. In fact I use 2 X 4.
07-13-2020, 05:48 AM
AR
I was worried about damaging the chrome KO spinners on my 66 Vette and experimented with boards, heavy leather, shot filled hammers, etc to protect them. Quickly learned this is not a good idea when I noticed one of them had started to back off and splintering wood was becoming hazardous to me, the wheel and the fiberglass. I've used nothing but a good quality lead Muther Thumper ever since and never noticed a mark on my chrome spinners or my ERA's aluminum spinners and I hammer them on pretty firmly. It's my own opinion that anything but a lead hammer directly on the KO spinner is not a good idea. Opinions may vary but not mine.
07-13-2020, 08:36 AM
VT
Quality shot filled hammers last much longer than lead hammers and tighten the spinner fully. Never had a spinner back off especially since they are reverse thread.
John
07-13-2020, 09:09 AM
Senile Club Cobra Member
NY
John
We have been told by wheel manufacturers that "dead blow" hammers are not to be used, they do not provide the "shock" that a lead hammer does.
rick@autoventureusa.net
07-13-2020, 01:05 PM
CA
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
USE THE LEAD HAMMER! If you want to do it, as trouble free as possible . I had to use the 911 tool and the lead hammer. Remember tight ass and you will never forget witch way they come on and off.
