Like Tree5Likes
  • 2 Post By bkozlow
  • 2 Post By cycleguy55
  • 1 Post By Karl Bebout
Old 09-16-2020, 12:27 PM
Cobra Make, Engine: built the molds and body composite construction
Default AN Torquing
pegasusautoracing.com just sent me an E-mail and in it it a very interesting article on torquing AN fittings and how many of us over tighten them. If interested go to the site and in the search box type AN torquing and the link to their article should come up. You might not find it interesting but I did.
Bill K
eschaider and 1795 like this.
Old 09-16-2020, 12:54 PM
cycleguy55's Avatar
Bill K
This one? https://www.pegasusautoracing.com/do...ocID=TECH00157
xb-60 and 1795 like this.
Brian
Old 09-16-2020, 01:21 PM
YES this is it.
Old 09-17-2020, 01:38 PM
Karl Bebout's Avatar
Good information. I'd always heard "not too tight" but this gives a definitive guide.
BigGuy likes this.
Karlos
Old 09-18-2020, 12:54 AM
eschaider's Avatar
Bill K
Thanks Bill.
Very good information and they have an excellent one page downloadable pdf with that and a bunch more. Great find for all of us.
Ed
Old 09-18-2020, 03:55 AM
1795's Avatar
Thanks a lot guys! Very useful. I have overtightened AN fittings in the past and learned to just get them snug.
Old 09-19-2020, 06:18 AM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
Those little cone washer/seals they sell look like a good thing to have around.
I've formed double flares, then corrected to 37 deg with stainless tube and over tightened and damaged fittings before. One of those seals would have been nice to use from the beginning in those instances to protect the fitting as well as adding a seal.
Old 09-19-2020, 08:29 AM
I just tighten them till they stop leaking.
Old 11-12-2020, 07:58 AM
In the article they reference Seal 7, well I ordered some just to have them around and they are very thin caps that go over the male end of an AN fitting and act as an internal crush seal, they are a bit pricey but if you have a leak they appear to be a quick fix and the fact they were developed for NASA to use on rockets seems to backup the fact they work. Some of our aerospace members may have more experience with them than I. I am hoping not to have to use them but they will be my first move to try and stop any leaks if a slight tightening doesn't work.
Bill K
Old 11-12-2020, 01:01 PM
eschaider's Avatar
Not everything built for rockets works. Don't forget The Challenger.
Ed
Old 11-12-2020, 01:44 PM
The Seco seals do work but are are usually are a last ditch effort to fix leaks.
Since they're dead soft annealed aluminum they cover for fitting and tube flaring defects. Going forward the Seco needs replaced every time the connection is opened.
Typically tightening the fitting and and loosening then tightening cures most leaks. Using Red or Green Scotchbrite and spin it on the flare with a suicide countersink helps a lot.
Old 11-20-2020, 09:12 PM
Years ago while working I found they were using a lot of SS fittings and were concerned about over tightening and galling.. these soft metal tapered rings that came in different size for different size A&N fittings. I was doing plumbing on my car and looked around and found they were available at Summit through a brand I can't remember. The ring fit over the male side and was crushed to seal putting the force on a small malleable ring. Ideal for the aluminum and SS A&N, JIC and so on. I bought several sets doing my oil cooler fuel pumps and filters ,regulators an tank fittings. I'm having a time just figuring what to call them for a search. They were a soft metal tapered ring that were compressed in the fittings union. They could be reused if you had not gone nut in the first place.
Mike H
Old 11-21-2020, 01:49 AM
Go up to my first message and link on to pegasusautoracing.com and in their search box type Seco-7 seal-8AN This should bring you to the page of their catalog that lists all the sizes or Cycleguy55 reply and link on to that address he references and half way down the page you will see a reference to Seco-7-seals hit that and it will take you to the same page in their catalog I referenced.
Bill K
Old 11-21-2020, 03:25 AM
That's it a "conical seal". You should not have to tighten as much to stop any leak. But still check surfaces for dents or scratches that would let fluids past. Those conical seal are offered by other vendors. I first encountered them on M1 tank engines.
Mike H
