| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
44Likes
12-05-2020, 09:40 AM
CA
Originally Posted by Grubby
Unfortunately for TKO owners, I bet Tremec will offer zero improvements.
John
And definitely no trade in incentives or loyalty atta-boys of any kind.
Considering their demonstrated (or is that demented), unsavory attitude and customer service performance over the last 15 to 20 years with these TKO boxes — not to mention their product performance, why would you possibly be entertaining some type of delusional hope for a product improvement or upgraded components?
A wise man would resolve never to buy from that type of vendor again. Vote with your feet and your dollars! It is the only message that they will understand - maybe.
Ed
Reason: Spelling & Grammar
12-05-2020, 11:47 AM
Tx
Cobra Make, Engine: UCC GT 427
Ed
Unfortunately, Tremec basically owns this market, albeit it’s a very small market. There’s no incentive for Tremec to do anything.
12-05-2020, 11:43 AM
Tx
John
I would hope Tremec incorporated improvements along the way, so that the TKO600 I purchased this year is the most up to date version. This is what any other manufacturer would do...am I wrong?
12-05-2020, 01:04 PM
Cobra Make, Engine: ERA #816, 427 Side Oiler
Absolutely NOTHING wrong with a TKO if you're using it on the street... I wouldn't get rid of it for the TKX. Now it's a different story if you don't have a transmission, buy the TKX. If you're going racing, drop a Toploader or a Richmond Competition 5 speed in it! And if you're racing then the cost of the Richmond shouldn't matter. You gotta pay if you wanna play!
12-05-2020, 10:49 PM
CA
There are many things "wrong" with the TKO 600 and the other members of theTKO family. These shortcomings have been documented in part in this and similar threads. If you are comfortable with your TKO purchase that's excellent. Don't worry be happy, as the old song suggests. There are many other owners that have buyers remorse and are not at all happy and yet others who experience recurring failures like Hauss who continually experiences fifth gear failures.
Shortcomings not withstanding the TKO. 600 is stronger than either the Top Loader or the Richmond 5 speed. Using either of those two transmissions would be a step backwards strength and durability wise.
Ed
12-05-2020, 10:38 PM
CA
Yup!
Tremec's demonstrated performance is the polar opposite of what you just suggested and has been for nearly two decades, probably even longer. In fact they still use a two piece countershaft in the TKO 500 with a single woodruff key holding the front and back of the TKO 500 countershaft together. That was one of the driving forces behind the birth of the TKO 600.
Tremec clearly understands the use of splined shafts and gears to transmit torque in the transmission, they use them everywhere, Why would they possibly use a single wimpy woodfuff key to hold the front and back half of the countershaft together? The same countershaft that transmits all the torque from the input shaft to the output shaft of the transmission?
BTW when they built the TKO 600 they went to a one piece countershaft to fix the two piece countershaft problem and then misaligned third gear because they were too lazy to do the engineering to build it correctly. It was a low buck get it out the door quick deal. In the FWIW bucket they never fixed the two piece TKO 500 countershaft problem they just introduced a new transmission, with its own shortcomings.
This idea of introducing a new transmission instead of fixing the existing product short coming is well worn model at Tremec. Think about it, The TKX is just the next box in the TKO line up — this time addressing TKO 600 shortcomings. It hasn't been in service long enough for the end user to discover its shortcomings — yet.
Fixes from Tremec for the TKO 600 — never did it before. I would be surprised to see them do it this time. Don't forget that takes away TKX unit sales for what amounts to parts sales for an old transmission.
Just what have you ever seen them do that would lead you to believe they would perform the way you suggest?
Ed
12-11-2020, 08:16 PM
QLD
Here is some more info on the 2-3 shift issue.
Note the OP also broke his 5th/rev rail from too many missed 2-3 shifts:
https://www.camaros.net/threads/trem...roblem.345361/
Gary
12-05-2020, 12:13 PM
CA
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Looks like a good opportunity for some aftermarket co. to step in and make a simple rail for us tko guys . Look at the tkx a simple clip to hold the finger on the rail. Wish I was a machinist I would start selling them right away.
12-06-2020, 08:56 AM
CA
To be clear, it is the rail, not the gear. A simple fix in my opinion . tremecs marketing however should open the door wide! for aftermarket companies .
12-06-2020, 09:27 AM
CA
Duplicate post
12-06-2020, 09:39 AM
CA
The simple answer to your question is in bold about midway down this post. The why and wherefore stuff is what is in front of and behind the answer.
For transmissions, strength is not a horsepower metric it is a torque metric. Most enthusiasts loose site fo this and fall back onto the romantic notion of who has more horsepower going through their transmission as an indicator of strength. Transmissions are torque multipliers and as such their measure of strength is their capacity to transmit torque.
There are three metrics that in large part determine a transmission's torque capacity (strength);
The first is the center to center distance between the mainshaft and the countershaft. The greater the distance the greater the torque capacity — all other considerations being equal. Larger center to center distances provide larger levers if you will.
Think of the distance from the gear tooth's optimum tooth contact point to the center of the gear as a lever. Just like when you use a pry bar to open a box, the longer the pry lever the greater your leverage. In the transmission it is similar but we rely on the gear ratio for the leverage. The center distance is a measure of how much gear mass that leverage (torque multiplication) is spread across. Not surprisingly more is stronger less is weaker.
Now expand the single gear image in your mind to two meshing large diameter / large center to center spaced gears vs two smaller diameter, smaller center to center gears. You don't need the math to get the right answer. The bid stuff wins every time!
The second metric is gear face width. This one is comparably straight forward. Wider faced gears are stronger than narrower faced gears. It's not rocket science. Once again in this situation more is better.
The challenge the design engineer has with large diameter, wide tooth faced gears is inertia. When you change gears, it is the synchronizer's job to match gear speeds on the gear change so you have a smooth (hopefully fast) gear change possible. The large diameter wide tooth faced gears have huge inertia.
That is one of the reasons the TKO shifts so poorly. It literally uses 1960's Top Loader synchronizers to attempt to synchronize much larger heavier gears than they were ever designed to handle. When Trmec did the T-56 they initially used double cone synchronizers because the gears were so huge. Later for selected OEM customers they began to supply (without a lot of fan fare) triple cone synchronization which later found its way into the T-56 Magnum.
The third and final (for this discussion) metric is the steel and it corresponding heat treat that the gears are made out of. We all have heard the common 4000 series molybdenum steel designations like, 4130, 4140, 4340 etc. There ar other steels up in the 8000 series that are used is some ring an pinions and a few specialty steels like the high nickel 9310 steel that is useed by Rockland Gear in their T-56 Tranzilla six speeds.
The overall strength of a given sized gear can be enhanced through the selection and use of specialty steels heatreated to a particular strength and hardness. Generally harder, tougher (hard to get both together) and higher tensile produce more desirable gears but each comes with it own set of idiosyncrasies the need to be catered to for a successful implementation.
Tremec uses a proprietary steel that has served them well (for the most part) in daily driver type applications. Rockland uses a particular 9310 alloy and heat treatment for the strongest T-56 six speed derivative available any where today. The Rockland T-56 style Tranzilla has a torque rating in excess of 1000 ft/lbs of flywheel torque. Liberty uses yet a different alloy for their Prostock clutches transmissions. Each alloy / transmission design is optimized for the target market the manufacturer was aiming at.
Now to your original question about the 1⅜ inch Top Loader input shaft.
By increasing the diameter of the input shaft you increase its strength only. It will have no impact on the strength of the gears internal to the transmission only the input shaft.
This becomes apparent with the original Tremec T-56 offerings for the Mustangs. Originally, they used a standard Ford input spline configuration. In service behind the supercharged 03/04 Cobra's these shafts began to shear off. The Tremec fix was to offer a larger diameter 26 spline input shaft based off a GM spline spec. It wasn't the spline count that saved the day (although it didn't hurt) it was the larger diameter input shaft. The input shaft change in diameter had no effect on the torque capacity of the transmission's internals, they remained the same.
You will see transmission manufacturers from time to time rate a transmission they offer at a particular torque spec. If you ask them how the transmission's torque capacity was determined (and you are persistent enough to pursue the answer) you will find that they have no real torque rating capacity available to them or that they want to use. Tremec does and for the most part their recommendations are pretty much the way it really is.
The aftermarket manufacturer that is blowing smoke up your behind will couch his torque rating representation with words like, "but not in a heavy vehicle" or in cars below XXXX lbs. This is someone who is trying to sell you a transmission and doesn't want the diminished torque capacity of the design to kill his sale. you should put as much distance as you can between those businesses, their transmission and your car as you can.
If a transmission is capable of XXX ft/lbs of torque transmission then it can do that in a light car or a heavier car. XXX ft/lbs is the same in either situation. What is not the same is the impact the gear teeth see at the time the clutch is released.
The shock loading on the gear tooth face from an aggressive clutch goes up considerably as vehicle weight increases. FWIW aggressive clutches that shock the drive train do nt perform as well in a race environment as a smooth engaging clutch that does not shock the driveline.
Ed
12-07-2020, 08:21 PM
Ed
Install "X" transmission in your car and get "Y" results.
Oh Jesus effing Christ man... blow it out your ass! Seriously, ban me from this site but dude you can't please everyone, especially your sorry ass. Do you work for Tremec??? No seriously, you must work for Tremec with as much horse**** as you spew here! I'm tired of this ****, another prima donna spewing hore**** here. Tremec is the ONLY transmission??? Give me an effing break!!! Obviously you have never raced ANYTHING. Please, enlighten us with your racing experience!!! Oh, I'd love to hear that!!! Go karts, slot cars... what else??? Oh, hold on...let me pull that up from XYZ's website and give you a bull**** answer!!! Again, these internet commandos have ALL the answers!!!! Please, adhere to all their recommendations and ask what NHRA team they work for...
12-08-2020, 02:37 PM
SA
Wow! Bad day...?
12-06-2020, 09:49 AM
Tx
I will just avoid “ power shifts”, which has no place on a road course anyway, and upgrade my TKO 600 if it ever fails. Like the Dude says “f*ck it”.
12-06-2020, 10:20 AM
IN
Cobra Make, Engine: ERA 838
Tremecs bread and butter is OEM sales to GM, Chrysler and others. We have seen iterative improvements in those OEM transmissions over the years.
T56 and TR6060 are strong and shift great. They are true performance transmissions.
They had no choice but to make improvements. GM would not tolerate no improvements.
The TKO hasn't changed much since introduction. They don't sell many, compared to an OEM application and thus don't make much.
They can sell transmissions that are sub par because there aren't many choices for aftermarket 5 speeds that can handle 600 ft/lbs.
I suspect they are seeing big slow downs coming in the OEM market. Demand for manuals is dropping rapidly. This may be motivating them to improve the aftermarket and sell more transmissions.
They didn't come up with the TKX because they are good people. They did it to improve their market position.
I was going to have to swallow really hard before buying a TKO for my current build. I looked into Richmond, but it wouldn't easily fit in an ERA. TKO was really the only option for OD behind a big block.
The TKX looks to have some of the DNA from the TR6060 and T56. I will buy that without too much concern.
I bet there will be a lot of cheap TKOs for sale in the next few years.
John
12-07-2020, 06:57 AM
WI
Neutral
I was always disappointed that the Richmond 5 Speed didn't offer a 5th gear overdrive ratio. It's been a long time coming, and as has been said, finally a viable alternative to the TKO.
Tropical Buzz
12-08-2020, 06:11 PM
CA
Surprised me too, Glen. He seems to initially think I am attacking Tremec and then he suggests that I work for Tremec!?!? Without skipping a beat he steps up his game with some personal attacks and then spirals down into an unrecognizable sort of banter that feels like another personal attack but is far too convoluted to comprehend.
His follow up commentary about keyboard commandos is also curious. It would appear that he is attempting to project certain personality traits, of his own, onto others he has chosen to dislike — for whatever reason.
I think you were right in your observation about a bad day or perhaps night?. It really is difficult to understand otherwise ...
Ed
Reason: spelling & Grammar
12-09-2020, 01:37 AM
QLD
Yes, surprised me also.
One minute asking about alternators; and then not long after, aggressive behaviour towards a longtime well educated member.
Gary
12-09-2020, 04:06 AM
AR
Some people just don’t have the temperament for forums and the back and forth and should probably just stay away.
12-09-2020, 10:13 AM
Patrick should heed this advice.
| Thread Tools |
| Display Modes |
Hybrid Mode
