Like Tree1Likes
  • 1 Post By MD427
Old 01-06-2021, 01:12 PM
Default Help identifying these brake calipers?
I have a Contemporary Classic, which should be using the Jag XKE suspension up front, including brakes. I understand in general the cars were fitted with Wilwood calipers on E-Type rotors. But they were also sometimes fitted with Dunlop or Girling calipers, possibly?
I am hoping someone can take a look at these photos and tell me what I have. I do not see any mfg. identifying information and the stamped numbers I find, I can not match up to anything in any parts catalogue.
These need to be replaced, so I'd like to know exactly what I have to make sure the replacement I order will fit and perform properly.
https://drive.google.com/file/d/1BcC...ew?usp=sharing
https://drive.google.com/file/d/1ajY...ew?usp=sharing
https://drive.google.com/file/d/1rgP...ew?usp=sharing
https://drive.google.com/file/d/1QAc...ew?usp=sharing
Hopefully these links to my shared Google Drive are letting you guys see the pics??
jwoodard likes this.
Old 01-06-2021, 01:45 PM
They look like early Jag XJ/XJS calipers.
Old 01-06-2021, 01:51 PM
LMH's Avatar
LMH LMH is offline
Look like Jaguar XJS to me. Maybe do a search and compare pics to yours.
Alba gu brąth
Old 01-06-2021, 02:21 PM
1985 CCX's Avatar
I cannot open but if Jaguar get the Wilwood version and the attachment part for the application and be done with it. I converted my old CCX to Wilwood and never looked back. They were way better....
BTW you could also just source the Jag units but probably more $$$
SNG Barrett would know
Old 01-06-2021, 07:00 PM
Thor maine's Avatar
Those are XJ-6 calipers , not sure who made them or in house by Jag or British Leyland??
Old 01-09-2021, 08:08 AM
Danr55's Avatar
I believe those are Girling Calipers. XJ6, XJ12, XJS.
https://www.ebay.com/i/284135709788?...RoCA8YQAvD_BwE
Dan in Arizona
CCX3209
Old 01-09-2021, 08:38 AM
1795's Avatar
They do look like a similar design to the Girlings that I purchased from BGDevelopments in the UK. They make reproductions of the Cobra, Jag and other types of Girling brakes.
Old 01-09-2021, 02:39 PM
CHANMADD's Avatar
those look like Etype arms and probably E type Brakes.....
Old 01-10-2021, 02:01 PM
Cobra Make, Engine: Ram SC
Default 4 pot front calipers
They look like XJ6/12 XJS
Jaguar fitted 3 pot calipers to about 1974 and then went to 4 pot from 1974 onwards. Any manufacturer will do as a replacement.
Not sure what they fitted to E types, but the wishbone looks like a E type.
Plenty of places in the uk will supply but postage will not be cheap as they are pretty heavy.
I’ve replaced mine a couple of years ago, and if I was to replace again I would look to aluminium as long as it had seals suitable to road use.
Roger
Ram SC 351 cleveland
on the road 8 years , nearly finished!
Old 01-10-2021, 03:12 PM
They do look like XJS/XJ6 about $100 per if you keep your cores.
https://www.rockauto.com/en/catalog/...b,caliper,1704
Or go thru Amazon
Right
https://www.amazon.com/Centric-141-2...omotive&sr=1-4
Left
https://www.amazon.com/Centric-141-2...motive&sr=1-15
Old 01-12-2021, 07:32 AM
Thank you all for the help/advice. They certainly look like XJ-6 to me, I'm glad that was mentioned because i had googled pics of XKE set ups and that didn't really seem to line up with what I had.
We just discovered the fronts have both seized open at some point along the way. Breaking was never very inspiring on this car. But I've effectively only had rear brakes for 'some' amount of time.
So for those reason I think I will try to find a more modern caliper, instead of going for direct replacements.
I know Wilwood is a popular choice on these cars for upgrading brakes. Does any one happen to know the model of those that would fit in place? It seems the XJ-6 mounting spacing is 3.5" so that is one limiting factor (it seems 'most' of their calipers are 5.25")
Old 01-12-2021, 10:35 AM
The Superlite series have 3.5" mounts. They are also available using intermediate brackets. You may have to "adjust" for other rotor diameters.
Old 01-12-2021, 10:36 AM
Cobra Make, Engine: Contemporary Classic Cobra CCX-3-3967
Default Contemporary front calipers
I have the following on my Contemporary Kit from 1996
New Wilwood NOS 120-3194R Superlite II A Caliper 1.38" Borex.81 Disc RH
New Wilwood NOS 120-3194L Superlite II A Caliper 1.38" Bore x.81 Disc LH
But I have the coli over front suspension which looks to be different than yours.
Old 01-13-2021, 09:20 AM
Ah, thank you! At least from that starting point I can look at the Wilwood published dimensions/clearances and get some measurements to make sure they would fit my application.
