Like Tree11Likes
Old 03-13-2021, 03:33 PM
chucks1's Avatar
Cobra Make, Engine: SPF, 395 Stroker
Default Time for a new battery, but what one?
My SPF is now 10 years old. Even though the original Optima (#8025-160/25) still works like a champ I figure it's time for a new one. I've done a little poking around for a replacement and see people complaining about Optima quality having taken a turn for the worse lately. Any thoughts or opinions on the topic?
Chuck
Old 03-13-2021, 04:50 PM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
I honestly have never had very good luck with Optima batteries but I have been very happy with the Odyssey batteries I have purchased:
https://www.odysseybattery.com/
jolsen42 likes this.
Old 03-13-2021, 05:05 PM
kitcarbp's Avatar
Default Duracell!
My Duracell Group 78 Battery is just turning 6 years old and not missed a beat yet. I use a charger on it during winter months to keep it fresh.
Old 03-13-2021, 05:26 PM
bobcowan's Avatar
For a street car, I always prefer to get the biggest battery that will fit in the space. And then some. I like having that reserve available should I ever need it.
AGM batteries are better (IMO) if the battery is in the passenger compartment, or over the foot box. If there's an accident, you don't want acid spilling on the passengers.
But AGM batteries require a more specific charging pattern than a standard wet battery. They are standard equipment on a lot of new vehicles. And they have an alternator controlled by the ECM to provide the right charging pattern.
That could possibly be why AGM batteries don't last as long in these kinds of applications. Maybe? IDK. But I have heard that Optima batteries can be hit or miss.
I prefer to buy batteries from Autozone. They are usually well rated. The price is good. And in the US it's pretty easy to find a replacement if there's a problem.
Interstate is historically an excellent choice. But it can be hard to find a replacement while traveling.
ACDelco (GM) is also an excellent choice. But they can be pricey.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 03-13-2021, 06:15 PM
Sycraft's Avatar
Cobra Make, Engine: ford 302
I am partial to the ACDelco brand
Old 03-13-2021, 08:18 PM
chucks1's Avatar
Some good information guys, thanks a bunch. Time to start researching a bit further.
Old 03-14-2021, 06:04 AM
t walgamuth's Avatar
I have gel batteries in my two hobby road cars. My dedicated autocrosser has a Lithium battery. My DD road vehicles have conventional batteries. For the latter I have been using autozone for a long time.
Old 03-14-2021, 02:59 PM
cycleguy55's Avatar
I've had good luck buying from Costco - both flooded and AGM batteries. Can't beat their warranty and customer service.
rads42 and spdbrake like this.
Brian
Old 03-14-2021, 03:08 PM
Likewise here Brian. Costco sells Interstate and their pricing is along the lines or their store...affordable.
Old 03-14-2021, 03:44 PM
Removed a dead 11yr old yellow top and replaced it with a red top.
Old 03-14-2021, 05:21 PM
twobjshelbys's Avatar
Most batteries are going from a 3yr-full+2yr-prorated to a flat 3. In Vegas with the heat they barely last 3 years, so we buy the cheapest 3 year battery we can get and for my truck with a group 65 that has been Walmart for the past two.
Sams club had the best price for my daughter's car and our Honda CRV.
CSX4005LA
Old 03-14-2021, 07:14 PM
ERA174's Avatar
Cobra Make, Engine: ERA 427, 482ci sideoiler
[quote=twobjshelbys;1490317]Most batteries are going from a 3yr-full+2yr-prorated to a flat 3. In Vegas with the heat they barely last 3 years, so we buy the cheapest 3 year battery we can get and for my truck with a group 65 that has been Walmart for the past two.
I've been using the Walmart EverStart Maxx for the past 10+ years. They last at least 5 years in my daily drivers and have a full replacement warranty for 3 years. The group 65 is rated for 850 cca and when new they test at around 1000 cca. The group 65 EverStart Maxx was given an above average rating by one of the consumer testing companies and sells for around $100. I've only had one out of about eight batteries that gave up the ghost within the warranty period and that was on my snow plow truck that sat for long periods between use. So, I highly recommend the EverStart Maxx, although if it is going into an occasionally used vehicle make sure you have a battery smart charger connected during non use/storage.
Kobura and Gilach1 like this.
Old 03-14-2021, 07:20 PM
Optima Red Top 34/78 (9004-003) - trunk mounted.
https://www.optimabatteries.com/products/redtop-34-78
Has standard and GM style battery connection.
Car starting hooked to the standard posts and
the GM connections have a Battery Tender extension
cord. I can hook up and trickle or top off charge
without venturing into the trunk to connect. Can
also connect a small Battery Tender voltage indicator to
the extension cable for status check.
https://www.batterytender.com/Batter...84370000000154
Battery is currently 3 years old and still going strong.
Old 03-14-2021, 09:25 PM
cycleguy55's Avatar
My Group 34/78 battery sits in a sealed battery box that's mounted sideways in the trunk, tucked behind the right rear wheel. The box has a tube that vents outside the trunk.
https://www.summitracing.com/parts/sum-g1230
I run external 'jump start' terminals under the hood. Photo below shows the terminals, but they're mounted without the bracket, directly on the chromed trim panels inside the engine compartment.
I can put a charger or battery maintainer on the terminals or check the voltage without having to open the trunk or battery box.
https://www.americanautowire.com/sho...art-block-prov
Brian
Old 03-15-2021, 03:05 AM
tonywyso's Avatar
Cobra Make, Engine: FFR Ford
Optima, my first one ( 34/78 ) lasted 12 years so, I bought another. Also get a Battery Tender well worth the money.
mln385 likes this.
Old 03-15-2021, 03:53 AM
Moritz55's Avatar
Cobra Make, Engine: Superformance, '65 427/MKIII with Roush V8 - 351W w/770cfm 4BBL Holley, 514hp
Similar to everyone here... but just like "tonywyso"...
My logic is to go with the highest cranking/deep cycle battery I can fit in the allocated space for an AGM battery. My SPF has the trunk mount battery similarly...
1st choice - Odyssey (could not find the right size with large CCA)
2nd choice - Duracell (CCA was less than the Red Optima)
3rd choice - Optima Red Top .. 34/78 (9004-003) had the highest CCA so installed it in my Cobra. https://www.optimabatteries.com/products/redtop-34-78
I add Battery Tender leads on all my sports cars and use: https://www.batterytender.com/Batter...nior-12V-0-75A
All my cars are on the Battery Tender when parked in my garages... longest battery life was 11+yrs old...
Cobra really cranks nice with the higher CCA !!!
Good luck .... let us know what you went with...
Alfa02 likes this.
Many thanks,
Mark
Superformance: SPO2454 , Titanium w/Black Stripes
Engine: Roush 427SR w/770cfm 4-Barrel Holley
Transmission: Tremec TKO-600
Old 03-15-2021, 06:01 AM
chucks1's Avatar
My local AutoZone store had one battery that would fit my battery box, but the terminals were reversed so it was no-go unless I wanted to get under the car, re-route battery cables and drill a couple new holes in the box. I know this because I took the damm thing home and dropped it into the battery box to verify. It's bad enough having pulled one battery from an SPF battery box; I thought number two was gonna get the best of me.
Back at AutoZone I asked about the Odyssey batteries but the cost just seemed prohibitive. Curiously enough, the store manager referred to the AC Delco's as being a "cheaper" variety of battery.
So now I have a new redtop on order. On a positive note, I know it fits the battery box and I know the cables reach the terminals, so once I drop it in the box it won't have to come back out until it fails. Hopefully I get a good one and it lasts a long time.
I'm a big believer in battery tenders. I use them on everything from hot rods to garden tractors and generally get very good battery life.
Moritz55 likes this.
Old 03-15-2021, 08:24 AM
hauss's Avatar
cold cranking is not as important as reserve capacity in a car that sits a lot. Get the most reserve capacity you can find rv/boat type .
Old 03-15-2021, 08:35 AM
Alfa02's Avatar
Gold Star Contributor
Both Cobras have Optima (Red top) finally changed the one in the 427 this year. Brought a NAPA (Gold top) AGM for the Mazda RX-7/V-8 car, seems just as good for far less money ?? Buying the best chargers, seem the ticket to a long lasting battery. Cheers TommyRot.
Old 03-16-2021, 04:28 PM
Costco, great battery. Good cranking and reserve, plus they will replace it if there is a problem, no questions asked.
rads42 likes this.
