Old 03-15-2021, 10:14 AM
Club Cobra Member
Cobra Make, Engine: NAF 427
Default My 8 stack EFI build
Hi all. As I continue to make progress on my 8 stack EFI build, I've come upon a rather curious situation.
I am using an FiTech fuel delivery system: inline fuel pump and filters.
I am mystified by the mismatching of AN fitting sizes on the FiTech system.
Starting at my tank: it has a -8AN fitting coming out of the sump (my dual 4bbl carb setup was plumbed with -8An fittings and 1/2" SS braided hose from the tank all the way to the fuel pressure regulator in the engine compartment)
Now the first component in the FiTech fuel delivery system is the "pre-filter" which has -6AN male fittings on the inlet and the outlet.
Then the in-line electric fuel pump (225LPH) has a -8AN inlet fitting and a -6AN outlet fitting. These fittings have metric threads going into the fuel pump.
Then the in-line filter has -8AN male fittings on the inlet and outlet.
So starting at the gas tank it would be a -8AN (tank outlet) going into a -6AN coming out a -6AN (pre-fiter) going into a -8AN coming out a -6AN (fuel pump) going into a -8AN and coming out a -8AN (in-line filter).
What's that all about?
I'll be changing them all to -8AN fittings.
Any thoughts on this?
The -8AN line would then run to the engine compartment to connect to the fuel pressure monitor block and the up to -6AN fittings on the fuel rails then out of the fuel rails to the fuel pressure regulator and the -6 return line to the tank
Greg
Display Modes
