January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree2Likes
  • 1 Post By joyridin'
  • 1 Post By t walgamuth
Old 05-20-2021, 12:01 PM
Cobra Make, Engine: FFR. w/ 351 Cleveland
Default NEED Help with Lower rad hose #
Hi to all, I have a FFR MK II with a 351 Cleveland motor and for the life of me cannot locate a lower radiator hose.. The # on the hose says:: (D) 71316CS , I have called gates, napa , etc etc all to no avail. This hose is Looooong, makes a couple 90s from the radiator and of course a 90 to the bottom of the pump... ANY help or knowledge is so appreciated.
Thank you In advance..
Ken H
Old 05-20-2021, 12:14 PM
This look like it?
https://www.daycoproducts.com/part?c...number%3D71316
https://www.amazon.com/Dayco-71316-C.../dp/B000C0UNW8
Old 05-21-2021, 01:14 AM
No sir, that hose is 16" long, my hose on the Cleveland is like 3 feet long. I've never seen a hose as long, but obviously someone makes it for some application. Someone on this forum must have a Cleveland motor and can help me out with the ID #. I'm hoping .
Thank you...
Old 05-21-2021, 05:39 AM
joyridin''s Avatar
I don't know about your hose, but the lower hose on my car is about 3 feet also. I had a stainless pipe made to go the distance and just used rubber hoses to connect it to the water pump and lower radiator outlet. I even had a small bracket welded on so I could attach the hose to a mount so it didn't flop around.
rads42 likes this.
Old 05-21-2021, 07:32 AM
Thank you for the reply, yes I am aware of that setup ,but this is a single hose with a mid section support, I may have no other option other than pull it off and take it to the local auto parts store and go in the back and try an match it up . I was just " hoping" someone on this board might have a 351 clevland with the rubber lower hose and a good part number for it . .I'll wait a couple days and see if anyone can help me. Thx
Old 05-21-2021, 09:54 AM
Cobra Make, Engine: SPF832, 466cid
Have you posted on FFR sites or searched this issue on this site?
Old 05-21-2021, 11:55 AM
sunman's Avatar
Is it maybe Autozone Continental Hose E71713
Chaney Shores Studio
Old 05-21-2021, 02:02 PM
Yes, I did search this site in depth, I thought,,,Windsor, no problem, Cleveland, different story.
Old 05-21-2021, 02:04 PM
Sunman, I will check that out, thank you.
I'm confident / hopeful, someone here Has a Cleveland and says : Yes ,here's the # of what you need......
Thx guys for your help and input, trust me, I have hrs and hrs trying to figure this damb hose out.....
Old 05-21-2021, 02:17 PM
twobjshelbys's Avatar
I found my radiator hose by taking the old one and matching up the bends, twists and kinks to a piece of a larger hose and cut off the ends...
I think for a run like yours having a steel tube bent to fit and using rubber transitions is probably a good idea. A length like that is prone to collapsing anyway.
Tony
CSX4005LA
Old 05-22-2021, 05:41 AM
Mystery Solved, so I pulled the bottom hose off, and where the mid section hose support is ,it had a rubber cover around that area ,after pulling the cover off, there is a 1-1/2" plastic splice, joining 2 different hoses.
Thank you all for your help, but this is my fault for not looking into ( pulling off the hose) prior to asking the forum.... Ken
Old 05-23-2021, 07:13 AM
tonywyso's Avatar
Cobra Make, Engine: FFR Ford
I have a FFR MKII as well and it's the same way. A heavy straight flex hose from the water pump then an adapter and a molded hose to the radiator.
Old 05-23-2021, 10:37 AM
Just a FYI for anyone that has a cleveland motor the 2 lower hoses Are E72357 which goes to the water pump and D71316 which goes to the radiator, I joined them with an aluminum 1 1/2" Billet barbed connector from amazon...
Old 05-23-2021, 10:58 AM
Danr55's Avatar
That's a Dayco hose available on Amazon.
Dan in Arizona
CCX3209
Old 05-24-2021, 04:54 AM
t walgamuth's Avatar
This looks like an excellent option. I would not want a hose 3' long made of rubber only.
joyridin' likes this.
