06-01-2021, 05:51 AM
Cobra Make, Engine: 1996 Excalibur Cobra 5L HO
Excalibur Cobra wont start how do I disarm anit theft system??!
I have a 1996 Excalibur Cobra with factory anit theft system and it will not allow the car to start I have to key fobs for it and they no longer work as of last night... can any one tell me how to get the car started and how to permanently disarm the antitheft system??
Thanks for any help!!
Dan
cell 407-466-6703
dandiehl99@gmail.com
06-01-2021, 08:57 AM
Dan,
Just a shot in the dark - I don't have an Excalibur so I don't know what the fobs you have look like.
If they're like others, they may have a small, button battery in each one. These are inexpensive, widely available and easily replaced. Mine can be popped open with a plastic upholstery spoon (kinda like a stiff credit card) and the rest should be pretty obvious. Some auto parts stores know how to deal with them too.
Could you provide a picture of one?
Tom
06-02-2021, 06:25 AM
Thanks Tom these have no batteries they are gray plastic little pointers with as I understand it an RF chip in them that disarms the system momentarily while you start car they are seriously a pain in the you no what
Dan
06-02-2021, 10:51 AM
Dan,
New one on me...
Do you have a photo or two?
Tom
06-03-2021, 11:44 AM
Disarm
Tom I have tried to post pictures on the site and i have had no success even for my bio info...
06-03-2021, 02:34 PM
Dan,
You have a PM.
Tom
06-05-2021, 06:54 PM
Dan,
If you have an OEM ECU and it sounds like you do, a tuner can disable PATS in the engine's tune. Not just because of PATS, but a whole range of other issues, if I were you I would replace the OEM ECU with a modern aftermarket EFI ECU. Both you and the engine will be much happier.
Ed
Reason: Spelling & Grammar
06-10-2021, 09:52 AM
Dan,
Just checking. Any resolution to the problem yet?
Tom
08-22-2021, 06:09 AM
Excalibur wont start - anti theft device
Went under the dash and found that the wire from the RF chip reader on yhr dash (flashing red light) that disarms ATD is a sheilded cable but rubber coated and the shielding had unwound and raw wire(s) were touching everything everywhere at the plug in - SO i peeled all back cleaned up the bare wires and retaped and everything works fine at the moment BUT i will say that i want to get this system turned off and out of the car! Its a pain and this is only a temp solution... also i am going to take advice and get a new recon EFI ECU and start over as there seem to be many other issues little gremlins around due to the age of the car and the engine changes improvements i have made - delet AC delet HEATER etc etc also disconnected IAC and car runs MUCH better and no need for IAC since no load from AC or Power steering or heavy electrical draw down, etc... your thoughts comments much appreciate!
thanks
Dan
08-22-2021, 04:30 PM
Dan,
I would keep the IAC even though you do not have the A/C etc. The new ECU will use it to control idle. Absent the IAC motor the ECU has no way to control idle.
Ed
