February 2026
Like Tree5Likes
  • 1 Post By joyridin'
  • 2 Post By 1985 CCX
  • 1 Post By Blas
  • 1 Post By spdbrake
Old 06-18-2021, 06:17 PM
Default problem with steering wheel shake
when I am driving on the street or highway and hit a pot hole or large bump in the road, my steering wheel shakes very bad. Steering box? control arms?
Old 06-19-2021, 03:14 AM
Cobra Make, Engine: Shamrock
Yes - either or all of those or even suspension bushes.
Old 06-19-2021, 05:41 AM
joyridin''s Avatar
It could be a case of bump steer depending on how the car is set-up.
twobjshelbys likes this.
Old 06-19-2021, 06:37 PM
Cobra Make, Engine: Lone star 351w /408cu.in.
Check your shocks for leakage, could be shot.
Old 06-21-2021, 10:16 AM
1985 CCX's Avatar
If your shocks have dampening you may be set too low. My AC did this as it was on the softest setting causing bounce. Once I dialed it up, handles like a dream.
Old 06-22-2021, 09:22 AM
Cobra Make, Engine: dd cobra,351w mild cam
Not knowing what make or how your steering is set up I can only speak of my own experience...I have a Mustang II set up and it was terrible and scary to drive over any kind of rough road...I had it lined up twice with no difference in the shake that I would experience...What I did was put my car on my lift and with out lifting it I measured the height of the body to top of tire and the width from center of tire to center of tire...then I lifted the car and removed the shocks which would let me move the suspension through its normal travel more easily...what I found was about 1 inches difference in width through normal travel of the suspension...so I bought a Bump-Steer eliminator kit for my style of front end and installed it myself...after a lot of measuring and trial and error and another alignment it is a lot better...not prefect but now I just get more of a vibration when I hit a bump or pothole...steve
Old 06-23-2021, 07:24 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
What tire pressure are you running?
Blas
Bruce.huling likes this.
SPFWiringDiagrams@Comcast.net
Old 06-25-2021, 05:33 PM
27 in the front, 25 in the back.
Old 06-26-2021, 07:32 AM
Steve,
Most likely its blown front shocks. The shaking after bumps is common with blown/leaking shocks on the BMW E36 suspension, which your car has. If you own a BDR?
Your profile does not reflect the model car you own or build #. Its helpful for folks responding to you with assistance to know what you own.
If you do a search in the Backdraft forum for "Shocks" you will find a few threads with part numbers, and instructions. Also it would be a great time to add Camber plates from IconicParts.com while you have the strut assys apart.
Old 06-29-2021, 06:07 AM
Danr55's Avatar
Check your rear wheels for tire hop. Feels like front end issue but is cause by rear wheel hop.
Dan in Arizona
CCX3209
