Like Tree2Likes
  • 1 Post By 1ntCobra
  • 1 Post By t walgamuth
Old 06-19-2021, 08:53 AM
Cobra Make, Engine: Everett Morrison/Side Oiler
Default Chassis
Most manufacturers chassis are made of mild steel and some are made of stainless steel. What are the pros and cons. And someday would there be one made of aluminum.
Old 06-21-2021, 07:56 AM
When you compare the stiffness/weight and strength/weight of those materials, they are very similar. The advantage of aluminum and stainless is corrosion resistance at the expense of being more difficult and expensive to weld.
It's the basic design layout that really defines how "efficient" a chassis is.
Old 06-21-2021, 08:50 AM
Default Chassis
But none are made of aluminum yet?
Old 06-21-2021, 09:50 AM
1ntCobra's Avatar
Abnormal CC Member
Kirkham has built 2 with billet aluminum frames that I am aware of.
Million Dollar Skunksworks Kirkham
The first one was apparently sold for $1 million USD to the CEO of Oracle.
Pace in Austrailia has a reasonably priced kit with an aluminum frame.
http://www.absolutepace.com/images/brochure_pace427.pdf
talos likes this.
Old 06-21-2021, 04:30 PM
t walgamuth's Avatar
My VSE has an aluminum Monocoque with a cast aluminum subframe up front designed and built by the well known Engineer Herb Adams. Herb and Matt built about 25 cobras with the Monocoque chassis. Four or five are aluminum, the rest steel. With an aluminum small block chevy and an aluminum rear end by Winters it weighs in at about 2000#.
talos likes this.
Old 06-21-2021, 11:45 PM
Cobra Make, Engine: Shamrock
Aluminium has one big disadvantage in engineering use - it is prone to fatigue failure so has to be very carefully engineered if it is to last through the years.
