November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-31-2021, 03:00 PM
Cobra Make, Engine: FF5 347 stroker
Default troubleshooting msd atomic II
Starts with 60 lbs of fuel pressure and runs for a second or 2. Fuel pressure drops to 20 and then dies. Sometimes will run for 5 seconds. New engine and just took off old engine which was running perfect. Help
Old 07-31-2021, 03:21 PM
Tom Wells's Avatar
Pump wiring? Pump bad?
Pressure should stay much higher than 20.
Old 07-31-2021, 07:57 PM
It is one of those ghost things. Pulled old engine, Put aside all wiring, power steering etc to the side. Put in new engine and this happens. Checked fuel pump initially. Was running perfect before. Puzzled.
Old 08-01-2021, 07:53 AM
Tom Wells's Avatar
hi,
Did you change any sensors? Do you need to reset the TPS?
Tom
Old 08-01-2021, 12:52 PM
G_Edmonds's Avatar
Cobra Make, Engine: Classic Roadster, 408 LSX
Fuel filter
I've spent most of my money on cars and women. The rest I wasted.
Old 08-01-2021, 01:10 PM
not fuel filter. changed and no difference. Got frustrated and put on a 750 cfm Holley. Runs great . Will try and figure out msd. tps did not seem to be the problem.
Old 08-01-2021, 06:23 PM
Tom Wells's Avatar
All I got left is maybe a not-so-good ground?
Old 08-02-2021, 05:40 AM
Going thru the wiring and ground connections. Will keep carb on until after Hot August nights is over and then try again.
