November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 09-08-2021, 10:56 AM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Default steering Wheel bolt pattern
Good morning all,
I need a new steering wheel . What came with the car is a 16" wood rimmed with the independent spokes which causes the hub to have a non symetrical bolt pattern. It has a 6 bolt pattern with a spacing of 2.5" across the center.
The closest I have been able to find so far has a spacing of 2.75. Also the holes
(2) at the top have a different spacing than the holes down either side.
A hub that matches the new wheel would solve the problem, but so far have not seen one for the wheels I've looked at have not shown or mentioned a matching hub,but it would also have to match the wheel shaft.
Anyone run into this problem before ?
Ted
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Old 09-08-2021, 11:59 AM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Have you checked the Moto Lita website? https://www.moto-lita.co.uk/steering...-split-centre/
Old 09-08-2021, 12:18 PM
MOTORHEAD's Avatar
mongoose; I don't want to replace it with another moto lita ($450 + shipping )
I'm looking for around $200 that might have the same bolt pattern as the orig wheel or an adapter to fit the shaft. If an adapter + wheel get close to 400, then it would make sense to go with moto-lita.
Old 09-08-2021, 04:50 PM
These folks have a Moto-lita in your bolt pattern for $275. 15" OD though.
https://mrsteeringwheel.com/moto-lit...teering-wheel/
Old 09-08-2021, 06:06 PM
MOTORHEAD's Avatar
SPD: thanks for the link, 15" will work just fine.
Old 09-08-2021, 07:55 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
What would prevent someone from cutting a one piece Mota-lita wheel to resemble the split steering wheel?
Blas
SPFWiringDiagrams@Comcast.net
Old 09-09-2021, 07:34 AM
MOTORHEAD's Avatar
Blas; I might give that a try. Depends on what I end up with. Waiting for David Kirkham to get back to me.
Ted
Old 09-09-2021, 12:13 PM
eschaider's Avatar
I am not sure cutting up a high dollar wheel is the short way home. Here are the PCD metrics for the MotoLita 6 fastener Cobra steering wheels. Except for the bolt hole thread specifications all other dimensions are in millimeters.
Ed
Old 09-09-2021, 12:36 PM
I have a box full of Cobra steering wheel adapters if you mess one up. You can have one or two for the shipping.
Old 09-09-2021, 05:21 PM
MOTORHEAD's Avatar
thanks for the help, guys. I've got one on order, we'll see if it fits when it gets here.
TED
Old 09-10-2021, 12:43 PM
I don't know if these would help but I have at least 4 of them
Old 09-10-2021, 03:31 PM
eschaider's Avatar
I was hoping you had the solid cast or possibly billet versions, readmt. If you did, I was going to attempt to take you up on your offer. I will leave these more modern versions for other needy enthusiasts.
Ed
Old 09-11-2021, 08:47 AM
Blas's Avatar
I have a spare SPF hub and adapter. If you would like to borrow it. Contact me directly. I have photos available.
Blas
Old 09-11-2021, 09:18 AM
I'll dig through the boxes-o-crap I have. I bought all the odd "stuff' from the original Finish Line when Jackie was cleaning out the back rooms.
