Like Tree2Likes
  • 1 Post By tortuga
  • 1 Post By 6TNCRZY
Old 12-19-2021, 03:14 PM
Default Superformance oilpan
Anyone R&R a 351w kick out canton type pan with the motor in the car? Without leaks?
Superformance 1764
Built 427W
Aiken SC USA
Old 12-19-2021, 03:22 PM
Cobra Make, Engine: FFR Challenge Car, RDI aluminum 427w
Might need to remove one or both engine mounts, mount dependent.
I built stud guides by cutting the heads off of 2" or longer bolts for the 4 corners. Made alignment easy and then installed a few of the smaller side bolts to secure it into location.
Yup, went together w/o leaks.
Jim
Old 12-20-2021, 10:59 AM
cycleguy55's Avatar
Give some thought to installing a set of oil pan reinforcement rails if you don't already have them:
https://performanceparts.ford.com/part/M-6674-351
When I did my pan I switched from bolts to studs and flange nuts, along with reinforcing rails. Used Permatex Ultra Black on the gasket surfaces. No leaks.
Permatex Ultra Black instructions: https://static.summitracing.com/glob.../ptx-82180.pdf
Canton pan? Check out the comments here about one-piece vs 4-piece gasket sets: https://www.ffcars.com/threads/one-p...25/post-867331
Brian
Old 12-20-2021, 12:40 PM
Default Thanks Brian!
Thanks for the great response with a link to the how to...
cycleguy55 likes this.
Superformance 1764
Built 427W
Aiken SC USA
Old 12-20-2021, 02:04 PM
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
The reinforcing rails should only be used on oil pans with a flat gasket sealing surface, many pans have a contoured sealing surface to better hold the rubberized cork gasket.
Old 12-20-2021, 02:08 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
You sure your leak is not the rear seal?
Blas
SPFWiringDiagrams@Comcast.net
