| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
4Likes
Post By HighPlainsDrifter
Post By strictlypersonl
06-30-2022, 01:14 PM
BC
Cobra Make, Engine: F5 Roadster
cobra exhaust pic
Hi,
I got my 302 block hugger headers ceramic coated satin black. Hooked up 2 1/2" pipes turned down at gas tank. No more burned legs
Perry
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
07-01-2022, 04:25 AM
CT
I'd put some insulation around that starter.
07-01-2022, 04:58 AM
Tx
Cobra Make, Engine: Antique & Collectibles, Forte 427 SB, TKO 600
Looks like you`ll have to drop the exhaust on that side if you ever need to change out the starter.
07-01-2022, 05:46 PM
Tx
Cobra Make, Engine: UCC GT 427
You should be able to clock that starter and move the solenoid, no problem.
07-01-2022, 11:13 PM
Not sure that even aluminum foil would fit around that baby... that is tight-tight!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
07-02-2022, 09:16 AM
Tx
07-03-2022, 05:48 AM
MO
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
Nice, show us the rest of the system. Where are your mufflers, where are your exits?
07-03-2022, 07:23 AM
BC
exhaust
The pipes go under the rear end and turndown 3" in front of gas tank.
Perry
07-03-2022, 07:12 PM
Cobra Make, Engine: SPF#0760
How about a mini starter. I don’t think any kind of insulation is going to save that end of the end of that starter.
Blas
SPFWiringDiagrams@Comcast.net
07-05-2022, 08:34 PM
BC
Mini starter
It is a Powermaster PowerMAX mini Starter and has lots more clearance than a stock starter. after 53 year of driving I have only ever replaced 1 starter, none in my cobras. If you read the tittle it was to show my undercar exhaust instead of the burned leg noisy side exhaust, real mufflers sound like a muscle car.
Perry
