| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
41Likes
05-29-2023, 05:45 AM
AR
Well, if it’s not completely symmetrical that will just be in keeping with the rest of a typical Cobra body.
05-29-2023, 03:14 PM
TN
Cobra Make, Engine: Factory Five Racing, 306, E cam
My thoughts exactly
06-02-2023, 04:37 PM
TN
Wind Wings
06-08-2023, 04:05 PM
TN
Slick Sand
06-09-2023, 03:51 PM
TN
06-09-2023, 10:04 PM
Good work...
it is coming along nicely!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
06-16-2023, 04:06 PM
TN
Well, I think this is the final shape. I've tweaked the PS corner a bit and repaired the cuts and holes where the old mounts were, just need to touch up the primer.
Looking forward, I need to decide on a finish. Im debating a color match, such as this...
or a two-tone look, perhaps an old English white, something like this....
Bring on the discussion, mean while I'll start on mounting brackets for the windscreen.
06-21-2023, 04:00 PM
TN
Sidebar catches
I’ve started work on the mounting hardware. First up are the catches for the windscreen side bars. When I got it everything was done with aluminum pop rivets. I’ll use stainless fasteners ,new stainless catches (seen here) with a safety and nyloc nuts.
I added a thicker piece of aluminum to give the catch more support.
I’ll clean them up and polish everything for final assembly.
06-22-2023, 05:19 AM
AR
Very nice work. It should look and function great when you get it painted.
06-22-2023, 05:38 PM
SA
Yes, good job. Looks very much like a craftsman has been at work
Colour comment? I think I would forget the white; that works OK on an MGB, but if it was mine, I'd be tossing up between a colour match, or a matte black or satin black.
Cheers!
Glen
06-26-2023, 12:30 PM
TN
I cleaned up the inside of the top and sprayed a coat of primer.
Leaning toward using a perforated vinyl headliner with a foam lining, something like this
06-26-2023, 07:09 PM
WA
My $.02 color match with the car. Can't hardly beat BRG for a Cobra, my next one will be another BRG 289FIA. Cheers Tom.
06-30-2023, 07:40 PM
TN
More sanding
I misted it with black as a guide coat and blocked it. Could have been worse.
07-01-2023, 05:57 PM
TN
After blocking the second guide coat. Looks better.
07-08-2023, 06:22 PM
TN
Final Fitting
07-09-2023, 05:19 PM
In
Cobra Make, Engine: B & B 289
Very impressed with what you have been doing. Not sure I would've taken on as much as you. Great job, keep it up. BTW, nice color on your car
07-09-2023, 05:28 PM
TN
Thank you!
I'm not sure I would have had I known what I was getting into.
I'm looking forward to seeing how your top turns out.
07-09-2023, 11:01 PM
Nice!!
Looking really good, John!
Paul
07-14-2023, 07:02 PM
TN
It’s Green
07-14-2023, 09:12 PM
Yah baby!
Nice work!
Paul
| Thread Tools |
| Display Modes |
Linear Mode
