Like Tree41Likes
  #41 (permalink)
Old 05-29-2023, 05:45 AM
DanEC's Avatar
Well, if it’s not completely symmetrical that will just be in keeping with the rest of a typical Cobra body.
ERA 782 Running
  #42 (permalink)
Old 05-29-2023, 03:14 PM
john4337's Avatar
Cobra Make, Engine: Factory Five Racing, 306, E cam
My thoughts exactly
  #43 (permalink)
Old 06-02-2023, 04:37 PM
john4337's Avatar
Default Wind Wings
I'm in a holding pattern awaiting arrival of the primer and new gaskets, so I moved on the the relocation of the wind wings. I plan on building side curtains so the clamp mounts needed to go. A buddy of mine had some mounting hardware so I went at it. Drilling the sidebar is nerve wracking, because, unlike fiberglass, there are no do overs. I got the top mounting block where I needed it and used the full wing assembly to locate the bottom block.
1985 CCX likes this.
  #44 (permalink)
Old 06-08-2023, 04:05 PM
john4337's Avatar
Default Slick Sand
Well, at least it’s all one color.
1985 CCX and DanEC like this.
  #45 (permalink)
Old 06-09-2023, 03:51 PM
john4337's Avatar
Well, I’ve sanded down to 180 and filled some small defects. The gaskets I ordered arrived, so I wanted to see if they’ll work out. I clearly have to do a bit of glass work at the anchor points behind the doors, but I knew those cuts were a wild guess
  #46 (permalink)
Old 06-09-2023, 10:04 PM
Thumbs up Good work...
it is coming along nicely!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
  #47 (permalink)
Old 06-16-2023, 04:06 PM
john4337's Avatar
Well, I think this is the final shape. I've tweaked the PS corner a bit and repaired the cuts and holes where the old mounts were, just need to touch up the primer.
Looking forward, I need to decide on a finish. Im debating a color match, such as this...
or a two-tone look, perhaps an old English white, something like this....
Bring on the discussion, mean while I'll start on mounting brackets for the windscreen.
PDUB, 1985 CCX and rustyrims like this.
  #48 (permalink)
Old 06-21-2023, 04:00 PM
john4337's Avatar
Default Sidebar catches
I’ve started work on the mounting hardware. First up are the catches for the windscreen side bars. When I got it everything was done with aluminum pop rivets. I’ll use stainless fasteners ,new stainless catches (seen here) with a safety and nyloc nuts.
I added a thicker piece of aluminum to give the catch more support.
I’ll clean them up and polish everything for final assembly.
  #49 (permalink)
Old 06-22-2023, 05:19 AM
DanEC's Avatar
Very nice work. It should look and function great when you get it painted.
john4337 likes this.
ERA 782 Running
  #50 (permalink)
Old 06-22-2023, 05:38 PM
xb-60's Avatar
Yes, good job. Looks very much like a craftsman has been at work
Colour comment? I think I would forget the white; that works OK on an MGB, but if it was mine, I'd be tossing up between a colour match, or a matte black or satin black.
Cheers!
Glen
  #51 (permalink)
Old 06-26-2023, 12:30 PM
john4337's Avatar
I cleaned up the inside of the top and sprayed a coat of primer.
Leaning toward using a perforated vinyl headliner with a foam lining, something like this
  #52 (permalink)
Old 06-26-2023, 07:09 PM
Alfa02's Avatar
Gold Star Contributor
My $.02 color match with the car. Can't hardly beat BRG for a Cobra, my next one will be another BRG 289FIA. Cheers Tom.
  #53 (permalink)
Old 06-30-2023, 07:40 PM
john4337's Avatar
Default More sanding
I misted it with black as a guide coat and blocked it. Could have been worse.
  #54 (permalink)
Old 07-01-2023, 05:57 PM
john4337's Avatar
After blocking the second guide coat. Looks better.
DanEC likes this.
  #55 (permalink)
Old 07-08-2023, 06:22 PM
john4337's Avatar
Default Final Fitting
Here’s the final fit. If goes well, next post it should have color.
  #56 (permalink)
Old 07-09-2023, 05:19 PM
indianamoon's Avatar
Cobra Make, Engine: B & B 289
Smile
Very impressed with what you have been doing. Not sure I would've taken on as much as you. Great job, keep it up. BTW, nice color on your car
  #57 (permalink)
Old 07-09-2023, 05:28 PM
john4337's Avatar
Thank you!
I'm not sure I would have had I known what I was getting into.
I'm looking forward to seeing how your top turns out.
  #58 (permalink)
Old 07-09-2023, 11:01 PM
Thumbs up Nice!!
Looking really good, John!
Paul
  #59 (permalink)
Old 07-14-2023, 07:02 PM
john4337's Avatar
Default It’s Green
After a lot of thought, I decided to farm out the paint. Mike at Spotlight Customs knocked it out of the park. He generously gave me an A+ on the prep work. The last photo shows the test panel used when I built the car 12 years ago.
KevinW, DanEC and rustyrims like this.
  #60 (permalink)
Old 07-14-2023, 09:12 PM
Thumbs up Yah baby!
Nice work!
Paul
