| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
13Likes
3
Post By john4337
6
Post By john4337
Post By DanEC
Post By PDUB
2
Post By john4337
02-19-2024, 06:12 PM
TN
Cobra Make, Engine: Factory Five Racing, 306, E cam
Side Curtains
Some of you followed my hard top project. Part 2 of that was side curtains. A friend loaned me a set of Europa spare’s frames, but the opening of the top was different and the mounded in flange was in the way so I started from scratch. There were a couple of prototypes that didn’t work out, but I eventually ended up with this design. In essence it is 3 inch wide sheet aluminum bent to serve as a lower flange/lower track combination. The main piece is 1/8 polycarbonate. A 1/8 x 1/2 inch aluminum piece was bent on edge to serve as the upper frame/spacer and another piece of polycarbonate was cut 3/4 inch wide to create the upper channel for a sliding section of polycarbonate. A buddy machined 5/8 stainless bolts and drilled into ferrules them to accept 3/8 inch rod as pins. The aluminum pieces were cover in vinyl to dress things up a bit.
Initial window blank
Testing flange angle
Bending the flanges
Ferrules and pin
Layout for ferrules
Really scary part
Big holes in the door
More photos next post
02-19-2024, 06:28 PM
TN
02-19-2024, 07:00 PM
AR
Looks like a great job. Very nice.
02-21-2024, 12:43 AM
Great work!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
03-18-2024, 04:45 PM
TN
Well, a little update. A test drive showed that the windows were being pulled away from the top at speed. I set them up so that they contacted the top before the door closed, hoping the tension would solve this. Not so much, so I came up with two clips. The first is at the top front of the window, and is passive, the window slips behind it as the door closes.
The nut you see here was for fitting, I trimmed the screw and used a nyloc for final fitting.
The second clip is attached to the window further back, you just turn it after you’re in the car.
We did a 175 mile lunch run after installing these and all worked well. We were comfortable even though the temperature was about 40. No rattles leaks or whistles, so we’ll call it good,
03-20-2024, 09:03 AM
SC
Really nice attention to detail.
Bill S.
03-20-2024, 11:24 AM
TN
Bill S.
Thank you!
03-20-2024, 02:09 PM
TN
Bill S.
Thank you!
