Like Tree5Likes
  • 5 Post By super
Old 11-30-2024, 02:24 AM
super's Avatar
Cobra Make, Engine: Superformance, #011
Default How to clean sand casted and unpainted alloy rims best?
Hello together,
has somebody good experience in how to clean sand casted and unpainted alloy rims best?
I have these pretty nice FIA wheels from Bob Lacey since many years on my car and meanwhile they look not as good as they were. Especially the oxide spots I have on them don't look very nice. Have you guys a hint how to get them looking like almost new?
If tried to clean the sand casted surface with oxalic acid which worked well, but the probem is that the machined areas will become dull and matte when they get in contact with the oxalic acid. Protecting / Covering these machined surfaces with tape will also not work perfectly.
Have you got better ideas?
Werner
Old 11-30-2024, 03:26 AM
mrmustang's Avatar
Gold Star Contributor
Thumbs up
Originally Posted by super View Post
Hello together,
Werner
"Naval Jelly"
Bill S.
Old 11-30-2024, 06:05 AM
super's Avatar
But isn't Naval Jelly for iron and steel, not for aluminum?!
Old 11-30-2024, 06:12 AM
super's Avatar
Old 11-30-2024, 10:04 AM
mrmustang's Avatar
Thumbs up
Henkel Corp 1415346 Aluminum Jelly, 8 oz
Old 11-30-2024, 10:44 AM
super's Avatar
Perfect!
Thanks for your hint. I will try to find a source for this stuff over here in Germany/Europe.
Old 11-30-2024, 03:35 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Try WD40.
SPFWiringDiagrams@Comcast.net
Old 11-30-2024, 09:34 PM
Harpoon PV2's Avatar
Back many decades ago, when cleaning antique Indian motorcycle cases, we would use Westey's Bleach White, which was formulated for whitewall tires! Gentle on the aluminum, looked great when done, and not much scrubbing! Cheers, Dennis
Old 12-01-2024, 02:21 AM
super's Avatar
Hello and good morning,
I searched a bit through the web, but I had no success. All of the mentioned good stuff seems to be no longer in production or not available on my side because of its ingredients. And WD40 will not solve the oxide problem.
So, I am still open for further input.
Werner
Old 12-01-2024, 08:35 AM
twobjshelbys's Avatar
Try dry ice blasting.
Tony
CSX4005LA
Old 12-24-2024, 04:20 AM
super's Avatar
Hello guys,
lets give you a short update to that what I did, because meanwhile I cleaned my rims as mentioned.
But to remember to the reason of this thread, first a screenshot to the situation how it was at the beginning of the cleaning procedure:
Now the procedure itself:
First I used oxalic acid (2 coffee spoons of the acid powder in 250 milli liters of warm water) to remove the oxide spots on the sand casted surface. Then I cleaned everything with a brush and a lot of water to get rid of the acid residuals. For the areas that were unreachable with the brush I used a small electric hand grinder with little plastic brushes.
Then, I cleaned the machined surfaces with a cleaning fleece that is typically also used for copper pipes before they will be soldered. After that, I removed the remaining slight differences in brightness on the casted surfaces that were still visible with a glass fiber eraser, someone of you possibly know this eraser from former times where technical drawings were made by hand with ink on parchment or foil.
This glass fiber eraser works pretty good, I never would have never expected that, especially on small surfaces with many details.
And this is the result:
... almost as new - I am happy!
By the way - let me wish you all and also your families Merry Christmas!
Werner
Cobrakeith, Alfa02, S1965C and 2 others like this.
Old 12-24-2024, 03:10 PM
1985 CCX's Avatar
Looks like mine ……..
Old 12-27-2024, 01:33 AM
Well done, Jeff!!!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
