  #21 (permalink)
Old 07-06-2003, 09:47 PM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default Here's the problem on my West coast...
The fuel filler neck (hole in the fiberglass body) is too small diameter to install real fuel grade line. Mine was delivered from West Coast with a piece of LOOSE radiator hose with NO hose clamps installed on the LeMans cap or the tank neck. Therefore, when full the tank leaked into the trunk, where I have a 600 watt stereo amp, etc....
Good thing I noticed the FUEL leak and installed a new piece of RADIATOR hose there. Why did I use radiator hose??? Because the hole in the fiberglass body was too small for the CORRECT fuel grade line. No way to safely open up the hole with power tools. It's right over the FUEL FILLER NECK
I will be BUYING a new aluminum fuel cell soon, with a smaller fuel filler neck as a result..... It's OK, I budgeted for it in my final price for the car. Check to see what the H*#$ was used in between your LeMans cap and the tank neck...!!!!
On the positive side, I have repaired most of the factory "boo boos" and my babe and I attended the Seattle international raceway's Vintage races today in my machine, it was a blast !
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
  #22 (permalink)
Old 01-11-2009, 04:55 AM
Cobra Make, Engine: stallion
Originally Posted by Mohuska View Post
Back in Black and I are trying to get all West Coast and Stallion owners together to share info and get together......please see thread Attention all West Coast Cobra and Stallion Owners........sign in and leave your e-mail addresses....Thanks......
I am a stallion owner, sidepipe49@yahoo.com Please put me in the information loop.
  #23 (permalink)
Old 01-11-2009, 11:19 AM
SoTxButler's Avatar
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Check out the "looking for Steve Arntz" thread currently in the Arntz/Butler forum. Bob Bennett is posting and he worked for Steve. Lots of info in this thread.
Russ
  #24 (permalink)
Old 01-11-2009, 12:06 PM
HI Cobra's Avatar
Sidepipe49,
Please note that the thread you responded to was posted in July 2003.
I'd be looking at the "Steve Arntz" thread which is current.
Flip
  #25 (permalink)
Old 01-11-2009, 07:22 PM
Default stallion
I talked to everett morission in Houston tx. he said he could make a top for the stallion or west coast cobras. he is supposed to send me all the specs. So anyone else needing a top, maybe this guy will work
