Old 01-01-2003, 02:36 PM
Default puke tank
Can anyone tell me the approximate deminsions of the replica 427 puke tanks. I'd like to put one in but I'm not sure if I've got the room.
Thanks, Steve D***ey
Old 01-01-2003, 02:50 PM
Jeff Frigo's Avatar
Of course it will fit, why wouldnt it?
Jeff
Mark Donahue
Old 01-01-2003, 03:57 PM
Steve,
If you're talking about the brass repro tank (we sell a complete one), it will fit if the height matches the specs in the manual. Others can be shortened fairly easily. However, you must use a small (stock) diameter distributor - not the extra-large aftermarket ones.
Bob Putnam
-E.R.A.-
Old 01-01-2003, 06:45 PM
Chaplin's Avatar
Bob-
Does that mean that you can't use a MSD distributor?
Replica is not a dirty word.
Old 01-01-2003, 07:49 PM
Guys,
Thanks for all your replies. I don't think I was real clear with my request. I'm looking for the deminsions of the oil overflow tank. With the battery over the passenger footbox and dual carbs I'm not sure I have room.
Thanks again, Steve
Old 01-01-2003, 07:51 PM
Bob,
Thanks, I did get an expansion tank from you. It fit well and looks great!
Steve #606
Old 01-01-2003, 07:54 PM
David Kirkham's Avatar
Original Shelby Owner
Smile
Steve,
We make them and I am sure it should fit. We have placed them on many cars with dual carbs. The tank mounts on the firewall, offset to the right side of the car out of the way of the carbs. The tank is a cylinder about 4 inches in diameter and about 10 inches long.
Old 01-01-2003, 08:04 PM
ERA535's Avatar
Hi David -
Is your email working?
Chaplin -
To answer your question - I purchased a new expansion tank (water) for my car and it hit against the MSD distributor. I had to make a 1/4" spacer to the move the tank away from the engine so it would work.
Pat
Old 01-01-2003, 09:12 PM
James Baldwin's Avatar
Subsistance du serpent
Send a message via Skype™ to James Baldwin
David,
Do you have any information on the tank you used (do you sell them)?
James
